Vintage bench grinder
George110
Recently bought this Craftsman bench grinder for $6 but i wanted to add a switch but I’m not sure of the proper wiring and what switch to buy. I’ve looked in other posts that say that you can just cut the black wire and connect the switch in between but I want to confirm first since my electric knowledge is limited.
G
George110
You can look the grinder up by make and model and see what the original was. No bench grinder was ever sold w/o an on/off sw.
I did look it up, but the grinder doesn’t have any holes/openings for a switch and I’ve read in other posts that they did sell grinders without switches and they were just hardwired.
American Locomotive
Rhode Island
To answer your question, yes, putting your switch in between the back wire coming from the cord will allow you turn the grinder on and off.
But I am also with Zeke that it seems really odd to build a grinder without a switch. Doesn't make a whole lot of sense to me.
The Cobbler
I find it odd and unbelievable that Craftsman supplied grinders without a switch.
but, yes, you switch the black ( Hot) wire. that's assuming the black is wired hot as it should be and if not, correct that too
show us a picture of the front of the grinder, particular the lower portion where switches normally are
dougf
Missouri
I believe I have the exact same grinder, I'll verify and post a pic or two for you when I get home from work tonight.
MoonRise
That grinder is supposed to have a toggle switch installed. And a wall cord. It was NOT made to be hardwired to a wall switch.
Notice the switch in this ad picture:
my bad, that ad pic is for a 19581 grinder, not a 19571 grinder. and the ereplacementparts schematic also isn't the right exact model either.
The 19571 parts list at ereplacementparts doesn't show a schematic and doesn't list a switch in the parts list either.
FredWanaker
NorCal
someone has already been into that wiring. This is a photo from online what the switch should look like.
cgrutt
I was skeptical but it does indeed appear the 19571 was hardwired to a separate switch on stand. If it still has a power cord I'd put the switch on hot wire (generally black).
FredWanaker
NorCal
also - thinking about it. I am a child of the early 1950's and dealt with a lot of dad's tools / appliances / radios etc when they needed repair. I am not an electrician, but I was trained in electronics of that and later eras. That grinder is supposedly from 1963-64. It may have been a two wire plug originally. When rebuilding something like that I always made sure a three-wire plug was upgraded and that the case was grounded as an upgrade. I also checked the two power wires to see if one showed some voltage/amperage leakage to the case - if so, make sure that the leakage is on the neutral leg and not the hot leg. That motor has a starting winding most likely and that has to be properly wired in. As a kid I can remember being lightly shocked by appliances where one would have to turn the plug over to be able to use it.
G
George110
Sorry for not responding sooner but I ended up replacing the power cord since it was all busted up and installed a toggled switch in between the hot black wire and it seems to work properly but let me know if there’s anything I can improve in the future since I’m planning on restoring the whole thing. Thank you for all the guidance. I attached pictures of the grinder before I drill a hole for the switch.
wyliesdiesels
Modesto, CA
A hardwired grinder without an on/off switch would be really odd. Especially a small portable one….
FredWanaker
NorCal
from the photo it looks like it was sold with a grinder stand, and the switch was on the stand.
cherokee
Kansas City MO
if it don't come with a switch, easily enough to drill a hole and put in a toggle switch . and yes, ground the case too .
I am of the school that if it is impossible to make the thing work without altering it, I will alter it. If you can make it work like in the photo by @cgrutt I would do that.
To me keeping these things as original as I can while still having them be useful is where I am going. Actually with something as simple as a grinder if it was something like this and I did not have a good option for a switch somewhere else I would just set it aside and buy another grinder. This thing is over 50yrs old. I would love to use it, but I would not want to be punching holes in it to do so.
torqueman2002
SE Michigan
I don't have a copy of the owners manual for this model Craftsman grinder, but I have see other examples of the 1/4-HP models with out an ON/OFF switch.
0.25 HP m-397.19300 a
Above is a wiring diagram from a 1/4-HP model, showing factory wiring, with white/neutral going to the start-up relay.
Be sure the switch is motor rated.
dougf
Missouri
OP, sorry, I got side tracked. Mine is switched but it looks like you got a solution implemented. Weird for it not to have the switch built into it. I’ll have to do some digging and find some pics of the original setup.
DrFeelGood
Clackamas, OR
A little late but if anyone else comes down this road.
Below is a 1974 397.19581 (1/3HP)
gatornut2
I have the 397.19851 and here's a picture or two, works great.
Norcal
Foot switch! Solves all your problems and is safer too.
Not many are horsepower rated many are pilot duty, intended for controlling relays, contactors, & such, and a foot switch is not necessarily safer, all depends on how it is set up.
Doozer75
Buffalo NY
I know a bit about antique conservation, and I have or at one time had
machines in my shop that were 150 years old. Steam engine driven
type stuff. But your ideals about not wanting to drill a 31/64" hole
in a grinder to mount a toggle switch are a bit off the map.
You are entitled to your opinion, but I think reading this GJ board
has warped your sense of priorities. You will be dead in the grave
and your un-used grinder will be on the shelf, waiting to be thrown
in the dumpster when the next generation cleans out your stuff.
-Doozer
dave*99
Coastal NJ
-Doozer
My wife already showed me the special moving van she will hire to take my stuff to the museum when I’m gone.
Did you know my old dog went to live on a farm?
