We had a storm that caused the power to go on and off several times. The outages ranged between flickers to 20 seconds or so.
This caused the 30 year old A/C condenser fan motor to fail. I couldn’t get an exact replacement for the 1/4 hp, 230V, 1625 rpm unit , but I found a 1/3 hp unit with the same RPM and frame size. I reset the 30 AMP double pole breaker at my main inside box, and replaced one of the two barrel fuses at the outdoor cut-off which was blown.
I waited 24 hours, after the system was energized to let any moisture evaporate. When I switched it on, it worked for a few hours, but then blew the other cartridge fuse at the cut-off.
Before I burn through more cut-off box cartridge fuses, (or replace the box with a breaker), is there something else in the condenser unit, besides the fan, that could be making the fuse blow?
