I just purchased a mid-rise scissor lift that i'm excited about. I'm too old to be jacking cars up, setting jack stands and rolling under them. I have seen some other questions asked here about wiring for these but none of those questions is identical to mine. The lifts wires for power come off of a cam switch for power. It's a big red and yellow plastic switch that goes a quarter turn for power. The two wires coming from the switch to the plug or breaker are red and yellow. I assume these are the two power feeds for the 220v circuit. My confusion stems from no other wires in the pump cabinet. There is a yellow/green wire that comes off the pump that has been cut. I assume they use the same cord for their 120v version and just snip the green/yellow wire for the 220v installation.
I want to wire this with a plug (i have my compressor and welder with plugs and use the same 30 amp 220v outlet for them). So in wiring a similar plug for the lift I get that the red and blue wires need to make it back to the two poles of the breaker. Where do I wire the third wire from my power? Is it grounded on the motor somewhere? I'll try to post some pix in a minute in the hopes it makes more sense.
Wiring the compressor, the welder, the 220v circuit, etc was all pretty straightforward. This is not.
