King Chrome
- Joined
- Jul 29, 2023
- Messages
- 18
I have a second hand air compressor which had a another pump installed on it.
Starting it with an empty tank and empty transfer tube, the motor barely runs the compressor to 15psi before struggling to build pressure. The unloader also keeps venting when I turn it off. When I open the tank to vent to atmosphere or remove the transfer tube the compressor picks up speed and spins freely.
Here is a look at the unloader... is it even plumbed correctly? From what I've seen online it seems like it should go to a port on the check valve or a port on the pump head but here it's tied in with the pressure relief valve.
This is what the check valve looks like. It doesn't resemble the aftermarket check valves where there is some casing over the assembly. Is it bad? Did something break off? It also doesn't have an unloader port, neither does the pump head.
While I'm at it, does anyone know what this silver fastener in the center is? Looks like it may have had a wire in it once but idk.
