SpiderDave
- Joined
- Feb 17, 2018
- Messages
- 207
I'm building a 16'x48' lean-to. 2x10 rafters would run perpendicular from the shop at a 3:12 pitch, resting on a beam at the top of 6x6 posts, where the eves would be. (I may go with 2x12's, but I'm undecided.) Posts will be planted 32" in ground, spaced 12' o.c. It'd be about a 14+ft rafter span not including the 1.5' eves, etc. Then, plywood sheathing and metal roofing, rated at a snow load of 48psf.
My question is: Would using 4 mated 2x12's create a sufficient beam for the rafters to rest on?
Then I got to wondering how I'd properly alternate the seams of those 2x12's over the posts when they only come in 20' lengths? Should I put the posts at 8' o'c' then? That would be easier and certainly help any beam load issues if there are any, but it sounds cluttered. Most of the time I see people here spacing them at 10'-12' but rarely 8'. I feel like I'm missing something here. And LVL's or LAM beams aren't an option - just not in budget.
