Atlas Lath
skeer
Standish, MI Area
Nice! If your headstock has Timken bearings then there's a decent chance the mfg/assembly date is inscribed on the outer race. The unit I used to have was 1939, before they used the metal serial/model tags. With that different styled apron, and your headstock pulley cover I'm placing a $2 bet its around 1948-1950
Might this help? Guess not too many dates there.
This is light on details
Maybe here, this has lots of entries.
maxpower_hd
Massachusetts
I did look at both those links and wasn't able to find mine. I'll look at the bearings next.
  • Like
Reactions: RTM
maxpower_hd
Massachusetts
Actually now that I am on lunch I was able to easily take off the chuck and the nut behind it. The bearing says 10-17-50. So apparently it is a 1950. Thanks guys for the help. Now I just need to learn how to use it! Not bad for FREE.
4x4Pete
Stroud
Google hobby machinist. There's a forum dedicated to hobbyist machining. Pretty good overall. I looked into my SouthBend Heavy 10 and learned a few tips about it and how to use it. Good luck and have fun!
Aaron_W
Apparently Atlas records were either not that great or they got tossed out over the years. Unlike some brands that kept very good records (Logan was able to tell me when my lathe was built, as well as the reseller they sold it to) most serial number references for Atlas machines are based off of finding one near your number where it is known when it was sold. There are fewer and fewer of those original owners of the older machines still with us to provide that information.
Apparently one major way to determine approximate age is the bed thickness, the Craftsman lathes went to a thicker 1/2" bed way vs 3/8" around 1950-52. In the late 50s, there was a significant redesign of the lathe. Atlas dropped their 10" lathe for a new 12". This later model 12" was also sold by Sears as a Craftsman until the 1980s.
