Du Pont No 7 Tar & Bug Remover?
lschwarcz
Hillsboro, OR
Hi everyone,
Hopefully I got the right forum for this question. I figure that a solvent to remove bugs & tar is a tool :).
Long ago I used to use Du Pont No7 Bug & Tar remover. The stuff was great! But, I can't find it any longer. I've heard it was discontinued.
Has anyone seen this stuff recently? Is it still available but maybe under a different name?
If not, any suggestions on something that will work as well?
Thanks!
Larry.
Shiftless
East Bay SFO
I use Turpentine to remove tar and tree sap from the paint on my Volvos. Newest one is 2013 so I can’t vouch for paint from the last 10 years.
The usual advice applies… test first on an inconspicuous spot to see if a particular solvent will attack the paint on your vehicle.
seber
Deep East Tx.
Well we know gasoline will not attack the paint because we are expected to spill it. Definitely a tar and bug solvent. Same for diesel, ie kerosene.
P0234
NoVA
Large beach towel. About an hour before washing your car, drape the towel over the front of the car, spray it with water and let it sit. When it's time to wash, the bugs will all be soft and wipe off easily without using harsh chemicals that remove "wax".
onarant
Mississippi
I have used WD-40 to remove fresh tar and it worked very well. Went through an overlay project on the way home from work. Soon as I got home I sprayed with WD-40 and it came right off.
Don't know how it would do with bugs, I usually soap the the bugs up and let the soap soften them up for about ten minutes. They come off with just a little effort.
Wiz02
Southeastern PA
I like Stoner Tarminator and maybe a chemist can weigh in on what is the likely chemical composition based on its MSD. I always assumed it was mostly kerosene.
  • 91154-TARMINATOR.pdf
toolenthusiast
Most prepsols are highly refined Naptha or Kero based. Ive used Ronsonal (lighter fluid) to remove tar.
You sure can do that. You can also remove bugs and tar 1) mechanically 2) with off-the-shelf, purpose-built products 3) with less flammable, less breathable, less carcinogenic petroleum products.
Steve_P
I use paint thinner or mineral spirits when necessary - I keep it in a spray bottle. It does NOT harm modern paint - meaning in the last ~40 years. If you have a classic car with lacquer paint, then test accordingly.
AC-WC
NE, Indiana
This is the best stuff I have used, beats old #7 by far. Before the county chip and sealed our road they used to oil it once a year and it was always a mess. Works on old rubber from drag slicks too:rolleyes:
dvblanch
florida
WD40 sprayed on a soft rag works well same as kerosene or diesel but smells much better will not hurt anything and can also wipe off after w some car wash soap and water
toolenthusiast
You must have different thinner than I do because my thinner will dull out the clearcoat within seconds. Then you have to buff it back to a shine, so you could have just buffed whatever was on the paint in the first place.
