sticky oil
bb29510
i need some sticky oil in a can, like bicycle chain lube. I need to oil a concrete form and wd40 likes to run. One time i did it with a can of Pam
nadogail
Coronado, CA
I have been told that there is a product sold as Form Oil, but have no experience with it.
How did Pam work for you?
Vegetable Oil is readily available and inexpensive.
Kurt4440
Western New York
There are many brands of dedicated form oil available. If you are having a supply issue, you can use diesel fuel or a mixture of diesel fuel and motor oil in a pump sprayer.
A little goes a long way, avoid pooling.
bb29510
im using a pvc pipe as a form so its pretty slick to begin with, maybe wax will work
JABgj
So. California
No experience with this one but "Chain Wax" or spray can grease come to mind. Liquid at first but they set up.
rlitman
Long Island
Chainsaw oil has tackifiers added to make it stickier. It can be found in biodegradable vegetable versions too.
MovingAlong
Seems like you know what you're looking for. Is there a reason you're not using bicycle chain lube already?
A quick search on YouTube for "oiling concrete forms" brings up some product reviews. Sometimes nice to actually see the results of different methods. But I'm not a concrete guy...
Zeke
Seems rather costly to use chain oil on concrete forms. There are compounds for this, of course. Diesel was the go to and it works. Trouble is a lot of jurisdictions will write you up for pollution if they find it. If doing after any inspection, you should be OK. The fuel will do the job but you need a couple of applications if the form boards are new.
Monza Harry
Windsor ON
I have used a store bought "form oil" [I was supplied with a nearly empty bottle, so name was washed down and pretty unreadable] smelled like diesel fuel, a likely solution just a less refined diesel as paraffin was a problem with early diesels in cold weather but beneficial for this application. Years later on a much smaller job I used vegetable oil with good results. I painted my reusable form to prevent the form "suction" mentioned above. [Credit @Zeke] This was a fence post extension form for a re-grading project. Harry
