BEAVO
just what it says guys how exactly do i hook up a 220v receptacle for a future welder
You put the red wire on one hot terminal, the black wire on the other hot terminal, white on the the neutral, and green on the ground. Do it exactly like that and you'll be fine.
I cheated on mine. I went with 4 conductor and used a stove receptacle. I then made my 50' extension using generator wire, with 4 conductors. At the end, I have my standard welder socket (6-50R I think), and a pair of 20A 110V receptacles. It's a lot of extra wire, but when you need to put the compressor out in the driveway by the car to shorten up the hoses and make the most of the air you've got, the lack of voltage drop is well worth the price.
Against what?
Against what?
Um ... It's on a 30A circuit, 4 strands of number 10. The 20A receptacles are right on the very end, in parallel with the welder receptacle. It's no different than when you use an 16ga extension cord on a 15A 10 circuit indoors. Naturally it's never ever used for 110v and 220v at the same time and it's always used outdoors.
I may be wrong on the welder receptacle. It's the correct one for the welder, a Linc SP-170T. And I didn't produce this setup alone. It was implemented by a professional electrician.
oh I'm sorry I'm not a professional electrician buddy that's why i asked thanks for your 2 cents240....its 240......
not 220.
240..........
It's 240 and it's run not ran.
A welder does not need a neutral. Just two 120 V phase legs, thus the 240, not 220. Get a 50 amp plug and 8 gauge wire and hook up the two hot wires to the plug. Very simple to do.
first i would like to thank everyone for responding to my thread
oh and sorry i don't have perfect grammar i didn't know this was grammar school geesh guys why you guy have to be that way just ask a simple question errrrrrrrrrrrrr!! i like the site but you guys need to chill
That's the beauty of internet forums.If you ask a question,chances are you will get answers.For those who may not like to read answers they may not like,I suggest picking up a book instead.![]()
20A recepts get protected by 30's all the time, single circuits to dedicated equipment. (usually stuff with heavy cords, 14 or better) I don't worry so much about overloading the recept but the equipment you plug in to this circuit is likely to be designed to be use on circuits to 20A, even a 16 extension cord shouldn't be used at 30 ocpd.Cant protect a 20 amp receptacle with a 30 amp breaker. Is it going to be a problem? Probably not if you are careful to not overload the 20 amp receptacles. Is it right? No.
Totally. Some guys think a question is an invite to go on about ever-y-thing....![]()
And every electrical thread winds up in a code translation ******* match.
I think Spike TV should start a new reality series, "Electrical Code Challenge" with a bunch of electricians and jolt the piss out of everyone with a wrong answer. Or put 'em in a cage and let 'em duke it out.![]()
if i did i wouldnt be on here. just dont think people needed to respond that way because obviously i didnt know or i wouldnt have asked
but thanks to all that did respond and i didnt mean to start a pissin match
