What do I have here - Taiwan Vice ?
This vice was my Grandfather's and I would like to know what type it is?
What is its main function?
So nothing "special" about it other than being a good solid vice. I am guessing it is from the 1970s or 1980s
The Gyro and Versa were pretty good and useful vises, often called gunsmith's vise, due to its flexibility. One of my luthier friends uses one for carving the neck, and internal braces.
Look up the Gyro, lots of pix showing the unique ways it can be mounted.
While I have you all here...I have taken this vice apart to clean it. It looks great!! The one issue is that when i turn the handle to open the vice jaws...they do not open up but the handle unscrews all the way. I read a few other post that talk about a washer that effects this function. I found that washer...my question is where should the washer be placed to regain that function? It is currently SLIGHTLY out of round20230831_203109.jpg20230831_203059.jpg
Second question...I have two choices for "regreasing" the vice: general purpose grease or extreme duty gun grease...any thoughts?
Thank you for your consideration
Kevin J.
I think that you put the screw through the dynamic jaw and then put the washer in the groove closest to the "T" handle. The washer will then push against the dynamic jaw as you unscrew the handle. The washer will require deformation to remain in the groove. A snap ring could be substituted for the washer and probably work better. That is a very nice vise.
Kevin J.
Kevin J.
Thank you Kevin. It is always good to have a little input to help get you over the hump mentally when working on something you have little knowledge of. I spent some time looking at it all and pondering how it works and you have helped me a bunch.
Thanks again for replying
Farmer J.
UK, Cornwall/Hertfordshire.
The washer goes in that groove just beyond the end of the thread. After putting the screw through the dynamic jaw you slide the washer over the groove then hit or squeeze it from opposite sides to flatten it in to an oval shape so as it sits in the groove. Then it holds the dynamic jaw at the handle end and it pulls away as you unscrew.
Any grease is good, just keep it clean and don't let dirt build up in the threads.
Nice Vice, and it feels good to be using your Grandfather's tools.
Edit: Kevin beat me to the reply (y)
Boogerman
aspen cove hill
OP pictured vise cheaper version of parrot vise, which is pretty faithful copy of versa vise. The virtue of versa vise is self locks into position after pivot to where want and tighten work in jaws. It can also switch from horizontal to vertical. One OP pictured has manual locking, which is cheaper/easier to manufacture, and depending, may actually be more useful.
They're somewhat useful vises, I have two on my gunsmithing bench, prefer one with long thin jaws, instead of shorter, thicker mechanics vise type. However, prefer rotating, dual jaw Wilton pattern makers vise to both versa vises.
AreBeeBee
Wisconsin
If you have trouble securing a washer in that thin groove, consider two alternatives: a hairpin spring or an E-clip.
I had a similar problem with a Craftman vise, and the process of extracting the retaining washer ended up damaging it enough that it would be hard to reinsert and tighten.
See these posts of mine in the Vise Repair 101 thread, and scroll up and down a bit at both.
