I will second this experience.........never going back to cheap ****.All my gas and diesel cans are NATO cans. Mostly from Atlantic British. Real Wavian/Valpro cans. Real, all metal Wavian/Valpro spouts. They work great, seal properly, and last forever. Buy good cans and you’ll never go back to the cheap ones
Adding a vent to a No-Spill can defeats the purpose and is a waste of money. Doing that completely ruins the can.I use a No-Spill can and then get the vent kit off eBay. The drill bit is 21/64 if I remember.
No spill (Jill) only can I will use.
There are different types of no spill spouts. Most of them ****. Adding a vent allows them to flow faster.Adding a vent to a No-Spill can defeats the purpose and is a waste of money. Doing that completely ruins the can.
The whole point of a No-Spill can is the vent is a tube-inside-a-tube in the pour nozzle so that you stick the nozzle into the tank of a mower or chainsaw or ... and pour and you don't even have to watch it and never spill a drop, even if you can't see into the tank you are trying to fill. You don't even need to watch it. Stick the nozzle into the tank opening and push the button and hold it until it stops flowing by itself. When the fuel level in the tank gets to the pour nozzle it blocks the vent tube inside it and cuts off flow automatically. When it stops flowing, then release the button.
Best gas can EVER as long as you don't breach the can with a vent.
Exactly this.
There is only one type of No-Spill spout. It's a brand name, with a patent. There's plenty of other new 'ventless' style gas cans, but they aint a "No-Spill", and yeah, they ****.There are different types of no spill spouts. Most of them ****. Adding a vent allows them to flow faster.
I have some diesel cans like the one you pictured. They’re not horrible but not great either. If there’s room I put a funnel in the filler neck and just take the spout off the can and pour it in. Much faster and easier.
From reading comments about fuel cans I think “no spill” is generally used as a generic term for all of them. I don’t have my real No-Spill cans vented because they work reasonably well and I usually use a funnel and pour directly from the jug opening.There is only one type of No-Spill spout.
That’s what I’ve been using. Was curious if guys found anything better.These. I have four 5gallon and two 3 gallon. Every one of them is wearing one of these.
EZ-Pour® Replacement Spout Kit
This spout kit features a push-in vent cap for faster and safer emptying.www.menards.com
Check my post (#7) above.That’s what I’ve been using. Was curious if guys found anything better.
Did you say there was a gas can in that video?Exactly this.
And I'll third it...I'm done with the plastic rigs. Added bonus, if these NATO/Wavian cans fall over in your trunk or whatever, they don't leak like every plastic can I've ever had did.I will second this experience.........never going back to cheap ****.
I love mine but I want to shorten the spout some.Get these at Menards.
Plastic Product Formers Red Utility Jug - 5 Gallon
Plastic Product Formers has designed a red 5 gallon multipurpose utility jug made out of durable high-density polyethylene (HDPE) for many of your outdoor uses. It features an ergonomically contoured handle, a long flexible nozzle and a bottom grip for easy pouring. This is not a portable fuel...www.menards.com
I assume you read the full description.I love mine but I want to shorten the spout some.
Do some time in the slammer for using the wrong fuel can wouldn’t be much fun.I assume you read the full description.
"This is not a portable fuel container as described by ASTM, EPA, ARB and other official agencies. For Racing Fuel only, such as Nitromethane or Methanol, used in sanctioned motorsports. NOT for fuel used on highways."
How are these holding up?I got this set from eBay for some old cans that I got without spouts. No issues, but its only been 6 months or so. They have lived up to gasoline so far.
https://www.ebay.com/itm/254556997931
What brand cans are you using. Holding up ok?These. I have four 5gallon and two 3 gallon. Every one of them is wearing one of these.
I think I have two of these cans, if it's not these, they are darned close. They've been working just fine for several years since I threw the spouts they came with away.I need to get replacement spouts and vent caps for some older Gott and Rubbermade cans. The ones shown in the link look like they would work just fine.
Still working fine for me. No complaints.How are these holding up?
I have the same ones 2x gas and 1x diesel.Still working fine for me. No complaints.
Tried that. Even with a steel cap the gasket goes to hell. Tire valves are not made to withstand gasoline.If you need to add a vent, a metal valve stem holder with no valve stem inside and a plastic cap works good. Pull the cap to vent and if you loose the cap, pull one off your tire.
