Prevent rot in 4X4 Post sitting in Plastic sleeve it System
Nevika
Have 6' retaining wall. my contractor installed Sleeve it System (https://www.geogrid.com/en-us/products/sleeve-it-system) sitting on the gravels.
We are planning to have wood railing with help of 4X4 post. each post will be a 4"X4" #2 pressure treated- ground contact.
I am little concern when each 4X4 post will interact with soil and speed the rot in the post. I want this post to last for many year as it would set in concrete.
I am thinking to use a weatherproof vinyl sleeve post which will cover the post entirely from top but buries 1 inch into concrete so there is very less room for fungal growth or rot.
also it would help post from weather.
what would you recommend ?
Thanks
N
Nevika
That's true but it also depends upon type of application where rot could be prevented for some level. In my application, I can save my post for many year as sleeve is barrier between soil and concrete and the post will be sitting on gravels.
nadogail
Coronado, CA
Moisture and wood breed rot. If steel anchors are set in the concrete and the posts are bolted to them with drainage so the posts are not in direct contact with the water they will last a long time. Wooden posts in concrete might last 20 years, if you are lucky.
tarmy
Nor Cal
Copper green. Get a 5 gallon bucket and soak the end over night in it. I do that to ground contact PT 4x6s I put in ground.
kbs2244
drainage is needed
set the post in dry gravel
a cap on the top of the post to keep out water would be a good idea
PoorUB
Fargo, ND
I would set the posts in gravel, perhaps pea rock.
I have a fence I put up 25 years ago using 4x4 posts treated for ground contact, set in pea gravel. It is still solid.
N
Nevika
Thanks, I am still confused, even though without sleeve , How come it can decay wood in ground, it concrete and post both are protected/covered from a thick plastic sleeve. The only problem I am seeing from top where soil has contact with post.
acer66
Western North Carolina
Its the continuous drying out getting wet cycles that are causing dry rot which normally happens the most where the post enters the ground.
PoorUB
Fargo, ND
Concrete hold the water against the post. Gravel lets the water drain away.
I friend on mine has a ceder fence around his yard. Every post set in concrete has been replaced. Corner posts and gate posts weere set in concrete, the run of the fence set in gravel. A couple of the posts just set in gravel have been replaced, but when you consider 200 feet of fence and only a couple posts in gravel have been replaced, versus all the posts set in concrete it makes you think a bit.
N
Nevika
You mean where soil touches the wood post right at the ground level in my case, right .? So does post protector (https://www.postprotector.com/understanding-decay/) helps or any alternative ( still want to go with Wood due to budget constraints) ?
PoorUB
Fargo, ND
I am not sold on that post protector. It will still trap water like putting the post in concrete. It light protect against a weed trimmer, but I am not convinced it will help for rot.
Put the post in gravel and a couple inches from the surface use soil to grow grass. The gravel below will drain the soil and keep it fairly dry.
mikedodge
If the vinyl sleeve can get moisture inside it that's not good either because it can hold the moisture against it.
Gravel right up to the surface is the best way. It'll get wet but dry quicker and also help lock the post in place.
I built a fence in 2009. I thought the un treated un painted fence boards or 2x4s I nailed them to would need to be replaced over time but instead it's the pressure treated 4x4 posts. Last year some were noticeably soft right where they enter the ground. This week the first one broke at that point leaving that chunk of fence partially toppled over. The base of the posts are in gravel concrete mix with with soil on top, the only part that rotted is right where the post enters the ground. Above and below that level are still good.
Jbullfrog
Avoca, Iowa
Having looked at the link, you provided, you should be fine with the posts in the concrete, as that is how the system is designed. I would not recommend putting the vinyl into the concrete, at it would make it really difficult to repair or replace, if something happened to the post cover (think mower/ trimmer, fire). I would suggest wrapping the post, or treating it from the concrete, maybe 4" or so up with a sealer, and then topping the concrete with pea gravel around the post and vinyl to ensure drainage.
mslim
Fayetteville, AR
End grain is a sponge. Even in dry SoCal the codes required a patio cover wooden vertical support to have an airspace between it and the concrete slab. I can't tell you how many wooden fences in our area were blown over by Santa Ana's when the post rotted.
We used a Simpson elevated metal bracket. Do your footing however is customary and legal in your area and set the Simpson in the footing.
https://www.strongtie.com/postbases_capsandbases/category
P0234
NoVA
It's funny because I see whole towns on the coast with houses on treated wood directly in the ground. Some of them have to be over 70 years old.
mike93lx
Richmond, VA
Despite there being varying levels of treatment? It's not all the same
If the OP is buying wood rated for the same exposure as what you mentioned, absolutely send it.
I doubt that though.
N
Nevika
Thanks everyone for all your experience and suggestions.
How about using tricks by this man ?
P0234
NoVA
Just saying it’s possible for wood to be in very wet ground for a long time in response to people saying you can’t put wood in the ground. I think we agree that some sort of treatment is necessary and it’s not what you get on Home Depot lumber. That **** is now just sprayed to look like it might be water treated.
PoorUB
Fargo, ND
Years ago my dad would take new cedar posts and set them in a barrel with used motor oil and diesel fuel to thin it out. He would stuff as many posts as he could in a barrel and forget about them for a few weeks, then take them out and let them drip into another barrel before using. He always had posts soaking! The EPA would probably be all over him today, but this was back in the 60's, probably why we have the EPA today!
N
Nevika
DO I need to wait for the 4X4 wood to dry before i apply any oil or wood preservative and set in concrete ?
mike93lx
Richmond, VA
Yes. I would wait 20 years before setting in concrete. Should give you about 25 years of use
Seriously though, fresh PT is extremely wet. Any drying you allow it to do before coating will help it and the coating last longer
Uncle murph
Harford county
The wood you used 25yrs ago had arsenic in the preservative,good stuff,the wood being sold now has the enviromentally safe version of preservative.Its ****.
wssix99
Chicago, IL
This works really well and the posts I have treated like this have lasted decades in the dirt (and concrete). I used foundation coating.
