Wrench Holder.
Kenskip1
Missouri
Okay, So a short time back I posted about using 10 gage copper wire to help save space within my tool chest. Well, this did not work out as planned. So back to the drawing board. I managed to locate a old steel door spring loitering around in my garage. Anyway after putting the spring in a vise and now using my propane torch, I may have come up with something. Unfortunately the diameter of the spring was to small (about 3/4 inch) but the coils in the spring now being red hot did what I wanted. I could extend the distance between the coils or better yet decrease the distance allowing the wrench to fit snugly into place. So my next trip to my local box store I will pick up a return door spring and see if this idea could possibly be a success. It will have to be 1 inch or greater. Ken.
K
Kenskip1
Missouri
this Harbor Freight racks are pretty cheap, why mess with springs?
One is my local HF dealer is 45 miles from my home one way. Two, the spacing between the wrenches is to great taking up much needed space.. From the image show only two sets of wrenches will take up nearly a full draw. The draws are 16X2220230906_155712[1].jpg
Firebrick43
West central Indiana
Was the copper too soft? You might be able to harden it with a torch. Heat it up hot hot and let it cool slow. Then bend it into coils. Known as work hardening.
Hardening copper
Heating copper and letting it cool, or even quenching it in water anneals it or makes it softer.
And I don't know who wrote that article, but copper does not age harden like some other metals, particularly aluminum.
It does work harden, but will take some more effort than simply coiling it once.
xjfish
I dig it. Let us know how new spring setup works out.
flyingblind
Washington
You could run it through a rolling mill and then coil it. I have hardened copper pounding it out.
flyingblind
Washington
You could do that if you have a rolling mill, that will work harden it.
And you are correct that hammering it will harden it as well, very quickly.
Copper around a piece of acme rod and straighten then repeat, probably only take one pull straightening to make it hard enough. A vise has acme thread.
