HoosierBuddy
Back in the day, I could get a 40 Gallon NG water heater for $150 and it would last 8 or 10 years, and I was fine with that.
Then I did an upstairs remodel that took out my flue space for the water heater, so I had to switch to a power vent model. So, now replacement is going to be a bigger hit to the old wallet.
6 years in I decided to replace the anode rod, which is something I have never bothered to do before.
1. Total job was about 15 minutes. First step was turn the gas valve to pilot, shut off the water and drain about a gallon into a bucket.
2. If I wouldn't have used my cordless 1/2" impact, I don't think I'd have gotten the old one out. I spent a minute with a breaker bar and made zero progress. Problem is the water heater spins, so a cheater wouldn't help. Makita 1/2" 18V impact with 1-1/16" socket had it out in about 3 seconds.
3. The old anode rod was 99% gone. Should have replaced this a year ago.
4. I bought a magnesium anode from Amazon that is 4 1-foot sections that can be fed in from the top with low clearance. With a single 4-foot rod I would have had to drain and disconnect the water heater and lay it on it's side, because I only had about 20 inches clearance above in my low-ceiling basement.
5. LOTS of brown water created when I put the thing back in service. Assume that was rust and bits of the old anode rod that got stirred into the water when I refilled /repressurized the tank. I made sure to run hot water into the washing machine (empty) until it ran clear and then hit "cancel" to hopefully keep the wife happy next time she does whites.
Final step was to write when I changed it on the side of the heater in sharpie and "Change next in 2028" on it too.
Years ago I was told that the main difference in the more expensive water heaters, with a longer tank warranty, is they come with a larger anode. Not 100% sure that is true, but the failure mode of every water heater I've ever replaced is "Tank started leaking"....so you know....15 minutes. $29.
BTW...I THINK (not 100% sure) this is universal. 3/4" NPT threads and 1 -1/16" wrench required. My water heater is an AO Smith.
