rick carpenter
Is there anything better for replacing tool handle grips, specifically long nose pliers, than Plasti-Dip with their primer? I have an old Stanley pair with funged grips that I had to remove.
I've got a couple pair of Channellocks that need new coating on the handles. Sign me up for a 55 gallon drum!!This is what the pros use: https://store.gripworks.com/vinyl-plastisol-pails-drums.html
www.jerseydiscounttool.com
This is what I use. I get it off Amazon. Heat shrink. Usually use 1/2” and 3/4”. 2 layers work great.Someone was making slip on grips that you heat and they shrink to fit
That looks rather good - especially on the ratchets. I wonder if there is maybe a slightly thicker softer material that could be the first layer?This is what I use. I get it off Amazon. Heat shrink. Usually use 1/2” and 3/4”. 2 layers work great.
What is the name of the stuff. I want the name not the Amazon link as they do not work unless you are in the US.This is what I use. I get it off Amazon. Heat shrink. Usually use 1/2” and 3/4”. 2 layers work great.
XHFWhat is the name of the stuff. I want the name not the Amazon link as they do not work unless you are in the US.
