What is this used for?
Brian A
I found this on side of road, freed up all mechanisms, yet can’t find anything that tells me what it’s used for
Brian A
If it’s a block splitter than I wouldnt drag it to a job site it weigh at least 90. # I would just use a circular saw , cut off saw or grinder , Im on job sites every day and work with masons,hard scapers for 30 years never seen that also the jack works perfectly fine
Brian A
Thank you for replys I searched on line and some companies still make the damn things , basically a wast of $ when you can just buy a cut off saw ,I’ll still clean it up and probably make a small shop press out of it who knows
Brian A
I picked it up and put in my bed? I’m 50 but I can still lift heavy stuff for now especially if I want it , but seriously it’s for cutting pavers , I tried it and asked ahem and older hard scraper I know
And hey knew what it was , it’s pretty much obsolete
Brian A
I have video but was amassed it still works
signcrafter
Most saws dedicated to cutting block weigh a lot more then 90 pounds so this is a light block snapper. The big advantage is no dust, no blades to replace, and snaps a clean cut.
