Drill Press Motor Advice
countdown48
I am cleaning up a Walker Turner 15in floor drill press. I have 2 motor options and need some advice. I have a pretty old 1/3 hp Westinghouse motor that runs very smoothly and a newer 1/2hp GE motor. Both run at 1725 rpm, I have a 4 speed pulley for both, and both are already wired to switches. While I like the aesthetics of the Westinghouse, I am more interested in best performance so am leaning toward the 1/2hp GE. Am I missing anything where the Westinghouse would be the better option? Thanks for any advice or input!IMG-1178.jpgIMG-1179.jpgIMG-1180.jpgIMG-1181.jpgIMG-1182.jpg
Whitworth
If the GE has thermal protection without a reset button, it can pose a hazard when/if it re-energizes.
C
countdown48
There is no play in the older one so I am assuming it is ball bearing as well. The GE does have thermal protection but does also have a reset button
2oolhound
BC Canada
What size chuck are you running? Even if it's only 1/2" you still can use step drills to drill bigger holes. I'd go with the 1/2 HP, nothing less. My 17" with 3/4" chuck came with a 1HP motor.
