Woodworking expert opinion welcome
Clean up by hand(not to be hit with a hammer) after the waste roughly removed.
Usually the handles are loose, so they can be put into a tool bag or box. Beware the sharp bits falling off the wood bit and taking off a toe or two.
The technique I've heard is it is to be held, and pushed with your shoulder. Never used mine yet.
2oolhound
BC Canada
Think wood plane without the cumbersome body, just the blade that you hold. Guide the blade with your hands and push or lean on with your shoulder. They are like a wood plane so you just shave with it but because there is no body you can shave right into the end of a tight notch. This is how you achieve extremely tight fitting joints in timber construction and why they were most popular with ship builders (nothing worse than a leaky boat).
Slicks have a slight curve on the blade so that if you press the blade flat on the floor the handle is raised up and doesn't touch the floor. A framing chisel doesn't have this curve of the blade.
crguy what an unbelievable collection! That 6" is a wood shovel!
Mike'smeatshop
Thanks. That is very informative. Got me intrigued.
