Installing insulation on a metal building Any tips
600SL
Connecticut
I have done this before and it was very difficult especially the roof. Now 10 years later at age 66, I am building a steel building and tomorrow I will start insulating the roof. The building is steel with steel purlins and essentially a non walk-able 4 pitch PBR roof on top of 6" insulation. It will be on a 39' x 30' x 11' building. I am limited to myself and one other helper to do this job. I also have acess to a Geini lift. Any tips would be appreciated. The insulation comes in 6' wide by 35' rolls. The first picture is of my new garage. The second picture shows the insulation as it was being installed on my previous garage. One question I have is PBR seals. Are they really necessary if I am crushing down 6" of insulation down onto the eve beam?
My Old Tools
Hamrick Lake, TX
Seals can go in after the sheets if you need to. They are foam and can be "stuffed". My roof is 6/12 pitch. I didn't do it myself but they got it insulated and screwed down. I did have another 8" of insulation added to the under side of the roof with strapping, and it is absolutely worth it to stop radiant heat gain through the roof.
jthorn8
Lexington NC
Hi, I was wondering what kind of climate you are in. I am in North Carolina, in the summer it gets to 90's for a few weeks and in the winter it don't stay below freezing more than a couple days at a time. I am putting up my 40x60x-16 red iron building now, and I bought R19, 6" insulation, but I am debating going with the strap system like you say you have and trying to see if it is worth the difference, probably 7 grand difference if I can sell what I got. I do plan to heat and cool it and figure now is the time to do it the way is best. Thanks for your time.
My Old Tools
Hamrick Lake, TX
We are hot in the summer and humid. We had 20-30 days over 100 this summer. Had -12 two winters ago. Average winter temps are above freezing with a few freezing days on each big cold front. Most of your heat definitely comes through the roof. You can see the strapping in this photo.
Max78
Tucson, AZ
I used strong magnets to help hold the insulation in place while I secured the panels over the insulation. Worked great but my helpers didn't tighten the insulation in all areas so I got some drooping in areas where friends helped. Other than that it sucked.
coltonq23
is it okay to put it on top of the white vinyl insulation that already has the vapor barrier on the roof ? its okay to stack more on top?
My Old Tools
Hamrick Lake, TX
Walls and roof are single layer 4" roll with plastic backing, then the roof was strapped inside and 8" plastic backed ws added. The MrCool is pretty economical for me. I only run it when I'm in the shop. It cools it down reasonably fast.
coltonq23
nice !!!! thank you!! I can't decide on ac lol I have four large roll ups.
nadogail
Coronado, CA
When I worked at a local Ship Yard, the fiber glass insulation mats were held to the Steel Bulkheads buy fasteners threaded onto the studs that were spot welded in place.
Spot Weld guns are very easy to use, unfortunately they are not cheap.
There were also studs with bases that were glued to the steel bulkheads. I last worked in the shipyard about 40 years ago.
