dave*99
The story:
I found a Reznor WS44/62 fan forced hydronic unit heater that may work in my son's garage. 500 sq ft garage in Vermont. It's drive out garage under the house and has poured concrete walls mostly below grade. 2 garage doors in good condition.
A new propane fired boiler is being installed for the house and DHW. There will be a dedicated zone and pump available for the garage heater.
The hydronic fan coil has a 2 speed fan. Output is 44,000 or 62,000 BTu.
How do I control this unit? I suspect I need a thermostat connected to the Taco zone control unit. That's easy. How do I control the fan in the unit heater? I was hoping there was a thermostatically controlled switch in the heater that turns on the fan when hot water is flowing. I don't see that in the installation manual.
