Nice. Try to post some pics when she's still dippin but clean I love emm like that.
That's the big girl.Bingo… She is a Stanley no. 766
I like a stainles brush I think the brass ones leave a bit of brass color behind.![]()
All you need is simple green, PPE, brass brushes. And for the love of gawd… everyone to stop asking you to do stuff. (Minimal interruption)
Indeed! Your referring to yellowing, as present in picture for example. I have a secret.I like a stainles brush I think the brass ones leave a bit of brass color behind.
There is an insert rectangular bar on the bottom of the cylindrical slide, specifically to keep it in line and not rotational. There may be remnants of a ‘guarantee expired date’ stamped on that slide bar underneath… from there you can determine date of production. That ‘1935’ is called a casting number.
Hopefully, someone else can chime in WRT your electrolysis question.. I do not utilize the method.There is an insert rectangular bar on the bottom of the cylindrical slide, specifically to keep it in line and not rotational. There may be remnants of a ‘guarantee expired date’ stamped on that slide bar underneath… from there you can determine date of production. That ‘1935’ is called a casting number.
Here is a good read about the issues.I like a stainles brush I think the brass ones leave a bit of brass color behind.
Thanks, I figured 1935 seemed too old, and also thought it looked smaller than 4", but the seller said that it had 4 stamped on it somewhere that I've not found.1950-1956
Zeus, Firearms barrel cleaning solutions will remove it. Look for the ones that are for copper fouling. I have used copper and brass inserts in barrel vises and if there are any smears on the external surfaces, it removes them nicely. I have used whatever brand is handy, they all worked well at removing the discoloring.
Noted this. I’ll look into it. Thx!Zeus, Firearms barrel cleaning solutions will remove it. Look for the ones that are for copper fouling. I have used copper and brass inserts in barrel vises and if there are any smears on the external surfaces, it removes them nicely. I have used whatever brand is handy, they all worked well at removing the discoloring.
Hi Deb. This vise is not listed in the vise database at a glance. It looks nearly identical to a Dunlap 5244, except the dynamic on your’s has a relieved cheek.I have some questions about this Vise.
Western Hardware ExcelAll 400 swivel base, Milwaukee Wis.
Apparently not the Western Tool company who made the Champion Vise
I cannot find much information on this company. Just one reference that it might be the same company as Western Hardware & Specialty company. Founded in the 1930's? Anybody know anything about this company or the age of this Vise?
It works well despite the poor repaint on it.
Nice work. Sure those Wilton verde hounds will let it slide. You should buy the wife some dinner.
A little before and after of my Reed 206 since Friday. Man… what a transformation. So the stand ended up weighing over 500 lbs…. My poor wife trying to help me dolly it into the garage.
I don’t need a 6 inch vise… but I wanted one. I do all work in my vehicles so it will come in handy for suspension work!
I was going to clean it and put BLO on it but this color really suits it well (verde green).
Advertisements to include the no. 766 models.I had a senior chief in the Navy with an immaculate woodshop on base, that was his duty station. The dude knew nothing about woodworking, it was an easy senior slackoff job/orders, which is a comfort of khaki wearing dudes close to retirement. I use the woodshop and he got nervous… I said you won’t even know I was here. He liked that. Clean up your mess, and be invisible as possible. Based on the state of many peoples garages/shops around me, felt the need to say that.Surprised some of these dudes shops have not burned down.
No real problems with removing the nut, was just being patient. It matches mostly with the last faded catalog I just previously posted.. it is the steel jaws. idk about it being a sweetheart version, per-se.
Thanks Zeus! She def deserves more than that!Nice work. Sure those Wilton verde hounds will let it slide. You should buy the wife some dinner.butter her up for when you wanna move it around the shop again.
Thank you very much for the time to find this and inform me. The only reference I found was that they were the company that preceded the company with the name change that included 'Specialty'. The article seems to confirm this.Hi Deb. This vise is not listed in the vise database at a glance. It looks nearly identical to a Dunlap 5244, except the dynamic on your’s has a relieved cheek.
I did alittle digging on the brand and found this smallarticle from; ‘Hardware Age,’ Vol. 142, No. 7, Oct. 6, 1938, Pg. 60, info courtesy of reference; Vintage Machinery website.
Overall, there is little information about the branded company.
Nice mix of found objects, well doneJust got a big push at work behind me and started on a stand for a Wilton C-3 yesterday. Hoping to get it done, and the vise redone before winter.
Base- Gear from sugar factory 365lbs
Column- Steam injector? from scrap yard 85lbs
Plate- 30lbs
Vise- 160lbs
Total- 640lbs
Will be 45" to the top of the jaws, and the Big Wilton hangs forward enough that I don't think the gear will be too much of a toe stubber.
CD
Thank you, Sir.Nice mix of found objects, well done
