Miller Syncrowave 250 DX - School Me
Farmall450
Marengo, Illinois
Hi there. Just found my first water cooled TIG - a 2018 Syncrowave 250 DX w/ the Tigrunner base. It has the foot pedal, but not leads. The Miller literature advertises #300185 as their suggested kit, over $1k on their site but ~$613 from Cyberweld. Has anyone else found something comparable for less? The bare water cooled W-250/WP-20 torch kits I see online don't seem to have the "adapter" (pictured below) that the big kit has. Is this just the connector, and the torch kits assume you already have it?
Thanks!
sqznby
Coastal NC
Congrats on the new to you welder, can't go wrong with a Syncrowave. Smooth machines for sure.
You could piece together everything you need. I'd look for a CK set up personally, they are very nice and have a decent selection of torches available. You could get standard lines also but make sure to get a sleeve for them, well, get a sleeve regardless haha.
That is called a dinse connector. If you have a local welding shop see if they can get you everything you need if you are not familiar with everything.
Not to troll but I have a set of Miller lines (new) I'd sell for a deal if you're interested PM me.
F
Farmall450
Marengo, Illinois
PM sent. I have extra machines and my EZ Tig to offload :D
dr_clyde
Holland, MI
You can just buy the torch adapter and use any torch you like.
Old Syncrowave machines used a bolt on lug and these newer machines use a DINSE twist lock style.
This allows you to disconnect the TIG torch and hook up a stick lead without breaking the loop with the coolant inside. On the bolt lug machines we’d just hook up both the TIG and stick leads together and just deal with having a live lead not in use.
CK makes the best torches and leads IMO.
Sumboodie
AK
Had one for a while, traded a Ski-Doo 800 Summit for it. The Ski-Doo came from trading a truck.
Then traded the welder for a Grizzly LAR pistol and ammo.
Traded the pistol and $$ for a Polaris Ranger.
Sweetcorn
North Central Ohio
Great timing on this thread.
I just ordered a new CK worldwide water cooled torch yesterday.
Bakers Gas has the best prices going right now that I could find and I looked around quite a bit. Flex neck, 25 foot, water cooled 250 amp is $188.68 right now.
The ck dinse adapter is quite a bit cheaper than the miller one, FYI. Also available on Baker's site.
Congrats on the syncrowave. I love mine and it's hard to find someone who doesn't like them.
F
Farmall450
Marengo, Illinois
Wow, that's 1/3 the price of Miller (1/6 or 1/7 the price of list). Braided?
Sweetcorn
North Central Ohio
Took a pic for you for the routing of the cables to the adapter. The adapter in the pic is a "gas through" adapter. Some are, some aren't. Cover is off the adapter to show the routing.
I attached the torch to a Lincoln cool arc 40 cooling unit for the purpose of the picture. Whatever cooler or welder you tie in to will be plumbed like this.
The adapter then just plugs right into the the welder and you're all set.
It's easier to see it this way before its wrapped up with the cable protector and the machine is in the way.
sqznby
Coastal NC
I love CK, and that is a steal.
Not a fan of the flexible heads rather have a flex lock. But, that's what's great about CK, you have so many options.
Farmall450, grab that for sure.
86turbodsl
I love my CK 300A small frame torch. Definitely get the superflex lines. You'll hate using it without.
Love my syncrowave 300 even if it is ancient, it has really nice arc.
F
Farmall450
Marengo, Illinois
I need the foot pedal, regulator, work and electrode leads, etc. I looks like there are some complete Miller kits on marketplace - man these accessories are big money!
I ended up with 5 of them, and will probably be selling 2-3.
F
Farmall450
Marengo, Illinois
Thanks, that's about what I imagined. New to the water cooled world, but my "air/gas" cooled one gets smoking hot on AL.
BigMike782
Exactly which torch did you get?
I just looked up a FL2525SF and found it was 385.00
F
Farmall450
Marengo, Illinois
Sweetcorn
North Central Ohio
The miller isn't TOO much more:
I like the weldcraft stuff, but I've not had the greatest luck regarding durability with them. Don't get me wrong, they aren't bad at all and my experiences are most likely just my dumb luck. I still have a weldcraft on a syncrowave and its doing ok. CK stuff has been holding up really well though and I'm outfitting another machine, so I decided to go with CK again.
I'm sure you'll be happy with either.
Edited to add: that's not a flex neck in your link. I've really become used to those and probably wouldn't buy another without it.
sqznby
Coastal NC
You are correct, they are pricey but it's a buy once cry once kinda deal haha.
Both torches are great and will definitely last.
Send me some info on them, may be interested in one.
That is a Flex Lok not a Flex Head.
BigMike782
I saw that. I keep looking at the Flex Loks but I just cannot justify the money for the amount of TIGing I do.
F
Farmall450
Marengo, Illinois
Turns out they all have less than 200 hours (not sure what a good reference frame is, but that's about 2% of their life (5 years) assuming 40 hour weeks).
I can't seem to find what the first values at startup mean. I was speculating 231 volts (input) read, but it doesn't seem to fluctuate.
Sweetcorn
North Central Ohio
Wow, that's impressively low hours.
Do you still have any extra machine you're looking to sell? Please P.M. me with some details if you do.
F
Farmall450
Marengo, Illinois
The sad thing is the taxpayers probably paid full list for these. If that was really $10k (before leads even), on average that was ~$61/hour of use.
I'm glad the college got a grant (and there are grants for CTE), but it's sad to think of the high schools, other colleges, etc that could probably get 20 more years out of these.
F
Farmall450
Marengo, Illinois
I ended up ordering this kit. Seems like the best deal, and I wasn't ready to give up the flex head (my Hobart EZ Tig 165 has the miller flex) even if it will eventually leak.
pamike
Central PA
SweetCorn, I have a Synchowave 250 in PA I would sell. Also, for cheaper footpedal controls check out SSC brand. Part #SSC-C8101425. That should be a good number.
F
Farmall450
Marengo, Illinois
I put the CK kit Sweetcorn linked on tonight and it seems nice. Weldcraft zippered sleep and a few cable ties and it should be ready to go. Hoping to install the gas saver kit next and fill her up with coolant.
I'm assuming the Miller coolant is pre-mixed, i.e. you don't dilute it with water?
Sweetcorn
North Central Ohio
Glad you like it so far!
You are correct about the coolant.
BigMike782
I use generic ethylene glycol that runs 25-30.00 a gallon.
For home shop use I can see no benefit in using Miller or Lincon coolant.
BigMike782
Yeah, my dad says at his work they just use car stuff. I have 4 gallons of the good stuff, so I can feed at least one of them.
I was told to never use automotive antifreeze as it has silicates and those can clog the very small passages of a TIG torch.
F
Farmall450
Marengo, Illinois
I added some distilled water and let it run 10 min today like they say. Then I used it to pump out as much as it could (most of it). Need to grab a small pump or something to get the last little bit out, or just bite the bullet and add coolant.
Cleaned all the filters; nothing really in 'em other than some tiny scum.
dogdog
There was some thread on the miller forum to used non silicate base coolants. Means definitely no green ones. Some mention to use RV coolant. I think the VW coolants doesn’t have silicate as well.
