Looking to wire up power from 200amp main panel 175’ away that is from connection points. The garage goals… a small office which will need 20amp for a mini split, 4 post 30amp 110v lift for storage. (2)15 amp for led lights and outlets. 20 amp for TV/ coffee, 20 amp for mini fridge. I wont be adding anything else in addition as this will be max. Will run 2” schedule 40.
I have existing 500’ roll of 3awg THHN. Also new GE 125 amp sub-panel available. Located in central TX for reference…
1. What size breaker would be recommended for main panel to feed the subpanel?
2. What size ground from main panel to the subpanel (175’)
3. Will i also need a ground rod with solid #6 copper at the detached garage?
4. How deep do i need to set the schedule 40 in the ground?
Appreciate any advice needed!!!
Thank you
Thank you
