Absurd.Loctite, nyloc nuts, safety wire, reverse threads … I don’t like any of them.
They’re proof the designer knew that radial movement (within the necessary thread clearance) would cause problems. But instead of redesigning the joint to eliminate that movement, they used one of these hacks.
Until about the end of World War II, cars had left-handed lug nuts on their left wheels. The wheels sometimes fell off anyway.
Eventually someone designed the modern lug nut or screw, which has a deep conical seat that absorbs radial loads with minimal movement, relieving the threads of a duty for which they weren’t designed. Car wheels no longer fall off.
I don’t know the Italian moped flywheel situation but feel sure there could have been a better solution than threading them the wrong way.
Lug nuts still fall off if not tightened properly. It's the permeation of affordable torque wrenches and impact tools over tightening them that prevents them from falling off these days.
You seldom see people using the old fashioned 4 way to install a lug nut anymore.
My old semi has rights and lefts and they've never fallen off because I install them correctly.
Other fasteners need nylon, loc tite, etc because of vibrations.
Feel free to over-engineer a solution that only requires a 10 cent lock nut just to avoid using a 10 cent lock nut but don't be surprised when no one buys it.
