The Bear's Den
Bear
Salem, Oregon
Will try the pic again
Bear
Salem, Oregon
It is 40 x 48 x 16 and took two week to get up with son-in-law and a couple of helpers. I;m doing basic elect. now and hope to get the final inspection in a couple of weeks.
ag_streak
Blue Ridge, GA
F-f-forty by f-forty eight???
OMG! That's just beyond my wildest dreams! Woo-hoo! :beer:
Congrats on an amazing space! Boy, I bet that will take some time finishing it out!
Bear
Salem, Oregon
Ya I don't plan do get it done until next spring - but what fun to do! The plan is for a 22x 30 wood shop in the one end with storage over head.
Bear
Bear
Salem, Oregon
So - time flies when your having fun - I have started on the wood shop portion and have mounted two glue lam beams that are longer (about 36") than I needed (price was right). I am contemplting where to cut them off. I could just trim them flush and cover with the OSB, or someone suggisted I leave ?? for a landing in front of the storage area, STURDY shelf supports?
You comments and suggistions are solicited.
Barry
Stargeezer
Central Nevada, USA
Nice. Those beams are killer. I'd leave them. Landing is a good idea. Or a big HD shelf. Or you might put an anchor point for a hoist/block and tackle there.
Add a cross beam and many other cool things could be done with them..
mdbeck1
Norman, OK
Barry
It partially depends on what you are doing with the upstairs. If the upstairs is an office type area make a little deck with a couple of chairs for a place for a cup of coffee. If the upstairs is a major storage area you could put in a Hoist and use the deck for loading materials into your overhead storage...
Bear
Salem, Oregon
It is pretty much going to be storage - if you look close there is an I beam with plans for carriage and hoist.
Thanks
mdbeck1
Norman, OK
Thanks
I went back and looked and see a big I-Beam roughly centered between the beams and up next to the roof. I'm not sure what I would do with the laminated beams but I think that I would leave the large opening to make it easier to put sheet stock up there.
I still think it would be pretty neat to make a deck up there and do something interesting with it. Too bad I can't think of anything at the moment. I'm sure that some of the guys on this forum will come up with some good ideas....
Bear
Salem, Oregon
Yep - they are recycled from a firm that does demolishing of bldgs. as is the steel I beam up above. The glue lams are 7 1/4 x 16 1/2 x 24.
larry_g
oregon
Barry
I would definately go with a deck/landing there. It looks that you are on a farm with a forklift? then the deck makes using the forklift very easy. It is similar to what I have and the railing you see at the top of my stairs is quick removable when I need to lift stuff up into the loft. Your probably within 15 miles of me.
lg
no neat sig line
drivesitfar
Bear: any updates or STUFF you've bought to post pictures of in the last 6 years? I hear you that it's hard to get pictures then post them, but we are here to help if you need some.
thanks for stopping in on the PNW thread too.
Bear
Salem, Oregon
So after some gentle proding from Drives here are some updates to my build.
Starting with a Google view and then the beams arrive and get cleaned up.
Bear
Salem, Oregon
Son in law (the brains here) helping with rasing the beams and framing the wood shop/loft.
Bear
Salem, Oregon
And here is the loft - flooring going up and stairway
Bear
Salem, Oregon
Walls and cabinets going up
drivesitfar
BEAR: you've been busy. looks great. just one question how is the huge steel beam supported because it doesn't look like it is supported on the end that you are showing in your new storage area?
also how the heck did you lift it up there or do you have a huge fork lift.
WELL DONE SIR!!
thanks for updating your thread and showing us how to modify our pole buildings.
Bear
Salem, Oregon
WELL DONE SIR!!
Soo - the beam is supported w/ a 1/2" plate on top[ of the truss w/4 1/2" bolts through the flange. Probably not the very strongest of methods but is sufficent for any thing I want to lift.
drivesitfar
BEAR: any updates to the place now that you are settling in for winter? or maybe just some winter pictures to post?
cheers and hope all is well in your part of the PMW
