You ****!
Mike
I have had the 100 for over 20yrs.Brockhaus Heuer bench vise. These are forged and supposedly quite strong despite having less mass than a cast vise. The 120mm model opens to around 6”. Made in Germany and pretty reasonably priced on Amazon.de
The new TwinGrips got a Talon Grip brother today.
I honestly wasn't sure how different they would be, but after screwing around with them a bit, the Talons are going into the car box and the TwinGrips are going in the Home box. They might both be slip-joint pliers, but neither fit the classic definition (at least the one I have in my head), and they do very different things. For example, I whipped the heads off a couple decking screws and tried to get them out. The Talon Grip wasn't getting anywhere, while the TwinGrip just grabbed and worked. The Talons will go a lot of places the TwinGrips won't, and stay a lot more parallel.
Two entirely different tools for sure. Other than both being pliers, there's not a lot of overlap in my use.
those socket extension connectors really caught my eye. Need to see if there is a Cornwell truck nearby.I found myself on a Cornwell truck for the first time ever! They sponsored a semi-local car show and I had to stop for some goods. Mostly Blue Power and rebrands though unfortunately. I know their hard line tools are still solid but I already have everything.
Tekton haul of large 4-way angle wrenches and small crowfoot wrenches to round out my sets. Also a Snap-on Penta 5pt socket from eBay because I’m running out of tools to buy lol
Let us know how you like it. I'm looking for one myself.
Do your knipex twin grips have a bar code printed on their handle?The new TwinGrips got a Talon Grip brother today.
@jimf Thanks for sharing that. I was curious if the bar coded ones are inferior quality. I have a needle nose that has the bar code on the handle. Quality was not as good as their other pliers.
What are you referring to when you say the non-barcode are better quality?@jimf Thanks for sharing that. I was curious if the bar coded ones are inferior quality. I have a needle nose that has the bar code on the handle. Quality was not as good as their other pliers.
I have quite a bit of Knipex pliers. The ones with no bar code on the handle appear to be better in quality, Not sure on what others have experienced. Would be an interesting thread to find out.
I don't feel the Knipex plier quality is diminished with the addition of a bar code. To me, it means less packaging and no hang tag but, the quality remains high. Have you seen poor jaw mating, finish issues, or anything else wrong on a pair of bar code pliers? How exactly are the Knipex pliers without a barcode better?@jimf Thanks for sharing that. I was curious if the bar coded ones are inferior quality. I have a needle nose that has the bar code on the handle. Quality was not as good as their other pliers.
The ones in the pics I posted that have a bar code are the only ones that have ever failed with very light use. Maybe I just got some bad ones. I don't know. What I do know is that both the hose clamp pliers failed during one job/car(NSX). I actually sent them in for replacement, but have not used them since I've got the replacements.I don't feel the Knipex plier quality is diminished with the addition of a bar code. To me, it means less packaging and no hang tag but, the quality remains high. Have you seen poor jaw mating, finish issues, or anything else wrong on a pair of bar code pliers? How exactly are the Knipex pliers without a barcode better?
Custom made in the 90s. My dad used to be a sponsored triathlete. A lot of cyclists seem to know what it is and comment about it lol.How did that Bob Jackson end up so far from Leeds, DemoFly? I did a double take when I saw that name on the down tube.
