Model A Fan
I have a Craftsman drill press (standing floor model) and I recently moved it from my mom's house to mine and somewhere along the way, some stuff became loose. I'll describe my issues and I hope someone with more wisdom will be able to help me resolve the issues. Assuming I can fix the two issues, what would the value of this drill press be? It is in good overall shape, kind of a survivor/unrestored one. It works fine and has the center pulley which is rather desirable. I'd like to sell it once I get it working properly again. I can get more photos later, but these are the ones I have right now which are applicable to the problems I need to fix.
Problem 1: When I pull down on the handle, the handle does not automatically retract like it used to. I tightened the spring housing (on the left side) and now when left alone, there is spring tension pushing down the spindle and when I push up on it (retract the spindle), it automatically will push the spindle back down (as if drilling). How do I fix this to have the spindle automatically retract?
Problem 2: I pulled the middle pulley out of the head while moving/transporting it, and now I can't get the belts tight enough going from the motor to the center pulley to turn the center pulley and front pulley to make the spindle spin. Is there a diagram somewhere of the layout for this?
Question 3: How much is it worth? What would be a reasonable asking price? I bought it several years ago but have since acquired a massive Delta one.
Thank you for your help!
