Is Thorsen any good?
Hoot
Huntsville, Al
My opinion....... I would say that's a decent deal on extensions/adapters for the weekend mechanic. The universals may prove to be difficult to work with (floppy or loose??) But it takes some work to produce crappy extensions. I only say this because I have one or two "no-name" extensions (seriously, there is no brand name what so ever.....) that work every bit as good as my truck-brand extensions.
But, yea, kinda sad to see the name decline like that. I have a Thorsen ratchet that I used in my teenage years and mistreated beyond belief. It even did double duty as a hammer on several occasions. These days, the mechanism is a little loose and the chrome is chipping, but it's one of my more prized tools.....
vstoyko
Winnipeg, Manitoba, Canada
Too bad the Thorsen name is being disgraced so by the Chinese junk.
I started my career in automotive in the early 70's with a complete set of Thorsen and after a few years silly human trade pride caused me to buy Snap-on and Mac.
Thorsen was usually the first tool I grabbed because my Snap-on & Mac cost me dearly and I didn't want to abuse or lose them.
My experience with Thorsen was that the sockets broke before rounding out the corners like my Snap-on so it was no problem getting warrantee replacements. We use to take the soft Snap-on sockets that rounded out at the corners and split them on the end of a ball peen hammer clamped between the jaws of a vice so the Snap-on dealer would warrantee replace them because back then if they were rounded out the dealer would say no warrantee due to wear. My Thorsen 3/8" ratchet has 20 times the use of both my Snap-on 3/8" ratchets and still works like a champ. Both my Snap-on ratchets have had a few rebuilds and my SK died many years ago. I still beat on my Thorsen tools but never my Snap-on or Mack. The old Thorsen wrenches didn’t look like much but I preferred the humble industrial finish and thick rounded edge beams of their full length wrenches to my Snap-on or Mac. The Snap-on wrench beam is too sharp and thin for my liking and my Mac wrenches have the thicker squared edge type beam so both are uncomfortable in high torque situations. I can remember overhauling an old Chrysler diff and breaking my Thorsen 1/2" breaker bar/Johnson Bar (using a pipe for leverage) trying to pull the pinion gear through the bearing and collapse the collapsable sleave but when I grabbed my Snap-on after the Thorsen broke it bent at the pipe edge contact area so I couldn't get warantee.
I really didn't appreciate the reliability and performance of Thorsen tools until I started using my Snap-on and Mac more frequnetly after I lost quite a few of the Thorsens. I have since replaced almost all the missing Thorsen tools and hopefully I won't loose any more.
Blacknwhitepit
Eastern Tennessee
That is a helluva write up.... Hope you post more!!! :thumbup::thumbup:
Oh yea, IMHO... Thorsen was once a decent tool company whose name was sold out to cheap toolmakers.
-BWP
old salvage
Rhode Island
charlie_nj
My dad had a Thorsen set from back in the early 70's. They were US made. The ratchet was an open ratchet, the gear mechanism was not enclosed in a case. Made for a small head that would fit into tight spots. My dad did everything you can imagine to our old Chevy's with just that Thorsen set and a set of "Made in the U.S.A." open end wrenches.
Don't know what ever happened to that old set. If anyone comes across one of those old open Thorsen ratchets and is interested in selling it, I'd be interested in buying it for sentimental reasons.
All the new Thorsen stuff you see on Ebay is Chinese.
Fedwrench
Valley of the sun
What kind of quality do you expect for $5.99? I saw and used alot of US made Thorsen hand tools in the 70s in the Army. They weren't fancy but, they held up well. Unfortunately, as others have posted, the Thorsen name is now degraded to subquality Chinese made tools. Search the archives as there was a thread about a high piece count plier set from Amazon that left alot to be desired quality wise.:(
RRmech
Santa Fe, NM
You still see some used Thorsen-USA ratchets, sockets, and extensions occasionally on flea-bay.....usually fairly cheap too.
Steve
Paladin
Southern Utah
I've got a good bit of Thorsen USA sockets and wrenches. They are solid tools. Sad to see the garbage with "Thorsen" on them now...
T56 Impala
Roswell GA
I have a few of their vintage tools. My Favorite is the 3/8" speed handle. I have torn down many engines with that baby!
lauver
Belton, TX
Carwashguy,
The old Thorsen stuff is as good as gold. I see tons of it in the pawn shops at very reasonable prices. Whenever I see a Thorsen tool that would fill gaps in my tool inventory, I grab it, clean it up, and put it back to work.
As for the "New Improved" Thosen tools, I'll take a pass.
Paladin
Southern Utah
Carwashguy,
Hey, if you see any 13/16" or 1" Thorsen USA, let me know! Thanks! :thumbup:
Grandpasaurus
A long time ago I had a friend convinced that a Johnson bar was the bar that went between the bottom of a car and the drive shaft that kept the drive shaft from spinning. He was a bright guy, but had zero mechanical knowledge. Good times.
bonneyman
Desert SW
I have some old Thorsen ratchets. Bulletproof! Some sockets - quite good.
I'd say the old Thorsen was as durable as the older Craftsman. Say before 1970. I have a metric combo set from that era, missing the 16mm. Can't seem to find it, and it's kicking my OCD. :LOL:
matthew
I have a rail of 1/2” sockets that were passed down to me. Likely ‘60’s vintage, US made. Of all the stuff I’ve inherited, it’s probably the stuff i’m least attached to. No interesting knurling or styling. There’s a few sockets that were replaced, I suspect due to breakage. I may have broken one myself. I suspect they were fine for their day, but a reminder that some things are better today, like every inexpensive socket being flank drive.
I can understand a nostalgic appeal to those who used them long ago. And I like that there’s some guys on GJ that collect and are into Thorsen. But I also think Thorsen was among the companies that outsourced early, so I don’t understand who would think the name would carry much goodwill in the market today.
That said, the wrenches with the v-groove in the beam look pretty cool. If they had retro styling on the tools and a cursive script logo to go with the retro name, I’d probably be in…
Chrome Vanadium Cody
I got interested in Thorsen after moving near where they used to be made. I have a soft spot for no frills utilitarian tools like this. I would say the open gear ratchets are real gems though. Tiny head in 1/4" drive and just seem to work better than other ratchets I've tried in that style.
Davefr said:
I'm quite fond of the old Thorsen exposed gear ratchets.
Another member here several years ago referred to the Thorsen open-gear ratchet (model 77) as "the AK-47 of ratchets".
There was a reason the United States Armed Forces went to Wright Tool Company in the early 1990s and had them put back into production an "open-gear" type ratchet for use on vehicles in desert environments: they don't fail in service. The old Thorsen 77 was "the original" (subsequently copied by Indestro and Proto and Western Forge - branded as "Companion".)
Who did I send all the Thorsen stuff to at Christmas? Was that @Chrome Vanadium Cody or @BlakeTheCarGuy ?? It was a very deliberate move on my part; they are both young men and I wanted to impress upon them they didn't need to climb aboard that big white truck to get tools that would simply do the job.
Never got any feedback from them on the tools... although I cannot remember who got what.
Did you guys try them out? Get them dirty?
We sold Thorsen beginning at some point in the mid-1980s (when Indestro was no longer able to fill more than 30% of purchase orders.)
It was a decent line until they began replacing all the traditional "Thorsen" with "TAT" (Thorsen Allied Tool) **** from Spain and Hong Kong and Taiwan and Japan (we really weren't buying from mainland China back then.)
There's a great deal of confusion and misinformation about the company. The product was almost 100% U.S. made up into the early 1980s and the product quality was at least on a par level with the Craftsman product of that era, if not better.
When the product went to hell was after the "TAT" (Thorsen Allied Tool) imported stuff started coming in, and then "Thorsen" got the same sort of treatment as all of the other victims of the 1980s-1990s corporate merger-takeover-acquisition ****. For that matter, it may as well have been Bain Capital that was handling it - they screwed it up that badly. It should be clearly evident from the examples I've posted below that "Thorsen" got passed around like a $3-dollar *****.
The last and final iterations of "Thorsen" are laughable offerings from Taiwan and mainland China, most of which will get no more than a snide chuckle from the older members here.
It is worth noting this thread is 14 years old.
  • Thorsen 33921S 7-pc Metric combination wrench set (Ebay 233755806757 02).jpg
  • Thorsen 33921S 7-pc Metric combination wrench set (Ebay 233755806757 04).jpg
Ricky Joe
Roanoke, Va.
I fall into the nostalgia category. My first set of tools was Thorsen.
BlakeTheCarGuy
Roanoke Virginia
@four.cycle my bad on not giving feedback. I’ve always had good luck with Thorsen stuff. The ratchets are decent enough to use. Definitely better than those raised panel Craftsman ones. Their sockets great stuff, great fit, finish. Don’t need the fancy stuff all the time. Thorsen remains one of my favorite brands.
wayne55
I still have and use the Thorsen set I got with my mother's Top Value stamps back in the 1970's.
zendriver
Indiana
The combo wrenches look like something from Kmart, with chrome chipped off the ends, but they’re my go-tos for 45 years.
Picked up a flex head ratchet at an estate auction last year. It’s never slipping out of my hand, The knurling on the handle is so deep, the only way to clean the grease out is to dip the handle in solvent and scrub with a toothbrush. Use it often now as the ancient Snap On feels a little frail inside
They're usable tools. Not one to show off.
VolvoRyan
Kentuckiana, USA
This thread is as old as Thorsen was. Good gravy.
I inherited a number of Thorsen tools from a mentor, who was a Volvo Master Tech through the glory days of the OHC red blocks. He was mostly using Snap-On since the late 1970's. Thorsen was pretty good, considering that I still have some of the tools in front line use 50 years later.
Another sad, old tale in American manufacturing.
-Ryan
Yes you sent me a Thorsen deep socket set, thanks again! It has been my go-to set for home use and has been with me on many a fun project including building a wooden table from scratch on my back porch. This week I have to do some work on my uncle’s truck and I’ll put it to good use there.
^ When I was laying that stuff out and packing it up last Christmas, I sent one of you a "Proamerica" flex-head ratchet. Did that go to you? Or Blake?
I was curious about how THAT unit performed.
Glad you got good use out of those sockets!
Mgdoug3
KY
I have a 3/8 Thorsen open gear ratchet and a 1/4 Action made by Thorsen. I still use the Action one occasionally. It has lowest back drag of any 1/4 ratchet I own.
I have to admit, this one I used for a while but eventually sold it. I am kind of obsessive about trying lots of different ratchets and only keeping the ones I like most or else I’d have way too many. This one performed solidly and I was impressed with it since I hadn’t heard of Proamerica making a fine tooth model. 80 teeth and no complaints about strength- used it mounting some pretty heavy battery boxes that were at the upper limit of what I’d use 3/8” drive for. But 3/8” drive regular length flex head is a competitive category and in the end decided medium tooth but smoother New Britain and SK ratchets work best for me here. Definitely had fun putting this one through its paces though!
That’s part of what impressed me about these. With cleaning and a bit of lube they are butter smooth. I’ve tried similar open gear ratchets from Indestro, Wright, and Proto and none of them could match the feel.
Mgdoug3
KY
My 3/8 one is smooth but heavier back drag. It looks like new though so it's probably not broke in. It didn't say made in the USA. I don't know if Thorsen made it overseas or if it just wasn't listed.
rooster59
Land of the Pines
5/8 is a Norwegian 16mm
NoahG
Detroit, MI
Old Thorsen stuff is great because it isn’t one of the “****” old tool brands so you can usually grab em dirt cheap.
There's a thing about "gifting" stuff to other people. Once you put it in a box and ship it off, you no longer own it or have any say-so about its disposition - that is entirely up to the new owner. (We all have a female relative who does not buy into this philosophy, don't we?)
My objective was to see how that unit would work in the real world - I am not a mechanic by any stretch of the imagination. (I have a hard enough time just being a painter!) My sending that to you was not solely about altruism.
So... if you got some use out of it and pushed it, that is a good sign - I think they're making a pretty good product, they just have no brand recognition.
I was going to say something about the Thorsen open-gear, but held off, waiting for something like this from another member:
I do not own equivalent models in either Wright or Proto, but I do have several Thorsen open-gear units - in all three drive sizes - as well as several Indestro open-gear units - in all three drive sizes.
I was actually a bit dismayed to find that the Thorsen had a somewhat "smoother" action than any of the Indestro units. Not nearly as "clackity-clacky".
I had thought perhaps it was just my skewed perception.
