man there is no telling. the exhaust properties could have changed with the introduction of 10% ethanol. you never really know until someone smarter than you tells you so. or so I think..... oh well
Changing fuels won't have an effect on exhaust gases in the coolant, as CO2 is still a result of the combustion process, along with CO, O2, unburned hydrocarbons (HC), and nitrous oxides (NOx). Block check kits aren't full of black magic voodoo. The fluid is
Bromothymol blue, which reacts to CO2 (and the resulting PH change).
The reason that a gas engine turns the fluid yellow, while a diesel engine turns it green is because diesel engines produce less CO2 during the combustion process.
I've never had a false positive
with a two chamber tester, and fresh fluid. If you have any doubt, let the fluid sit for a while in the tester, if it turns back to blue, there isn't a significant amount of CO2 in the coolant. Old fluid can also give false positives, as can single chamber testers if they **** up some antifreeze. Two chamber testers are the way to go.
Edit: One thing to realize is that a bad headgasket doesn't have to be "blown". These tests aren't supposed to be an all inclusive "bad headgasket/cracked head checker", only an indication that something may be wrong, and warrants checking into further.
