I am putting a house back together after a flood from hurricane Idalia. The house is concrete block. On the interior it has typical 1x2 furring strips that the drywall was attached to and had some fiberglass insulation that has been removed. I am putting it back together with the lower 3' being removable to allow easier cleanup the next time this happens. One of the other things I was planning on doing is to paint the lower 3' with Drylok waterproofer paint and sealing any holes or cracks I find.
My question is if there is any real value to adding insulation back? It would be 3/4" rigid foam board on the lower 3' and that only has an R value of 5. Also if I paint the walls with Drylock will that cause an issue with creating a vapor barrier? And the floors are going to be bare concrete with area rugs. The house is 70's construction and still has the single pane aluminum framed windows as well. Its not wining a "most efficient" house award. Thoughts?
