Ratchet pet peeve
bchee
Texas
If you own a ratchet with 60 or more teeth, you might be able to relate.
You buy a fancy new ratchet with lots of teeth.
You put a socket on it, break the nut free, then it spins right off by hand!
Every fastener you encounter comes right off after you break it loose, you don't even need the ratchet....
If you're a pro, and time is money, I guess that is good, but not if you're trying out your brand new ratchet.
nate379
Palmer, AK
Nope. I always get the bolts that a PITA to reach and just tight enough I can't undo with my fingers but loose enough it won't drag the ratchet enough to let it ratchet.
bchee
Texas
I hate that too. Equally frustrating
bchee
Texas
It feels like buying a Porsche and taking it out on the highway into rush hour traffic.
Toolhorder
Montana
Same here. Or bolts that turn super easy with a dual 80 or 88 matco ratchet and then fool me into thinking I can take off the bolt by hand.
sko
Los Angeles
Because its made in tiawan. :lol_hitti
:rolleyes:
stop trollin' mine says usa right on it.
also on that note i got the 80 tooth ratchet and have yet to need to loosen a bolt where my swing is limited enough that i can take advantage of the super fine teeth.
