The PIC
JradM
Alberta
Haven't seen anyone discuss the new Picquic "The PIC".
I'm a fan of Picquic's multi-bit screwdrivers generally. They aren't PB Swiss, but aren't priced like it either. This one is a pocket-friendly shape and holds three bits.
Handle made in Canada, bits in Taiwan.
The 2" bits can be used with an impact driver. PHILLIPS #2, Robertson #2 and a 3/16" flat blade are included. Picquic bits are quite good in my experience.
Bits are retained in the handle by the O-rings. Certainly not fancy, but they don't fall out or rattle.
At the business end, the bit is retained by a magnet. The bits actually sit quite deep and the magent is strong.
Seems to me that double-ended bits would work fine too - no problem retaining a bit inserted backwards.
I'm guessing Picquic used single-end bits because the part they slot into is just plastic - the extra contact patch helps make it strong enough. The bits probably sit so deep for much the same reason. If you didn't over do it though, double-sided bits would be nice.
I like it. It's light and small, fits easily in my pocket, uses standard 2" power bits and cost $8.99 - Canadian. I might just screw on a pocket clip because, why not.
Most screwdrivers with full-sized bits are a bit too thick to comfortably pocket carry - or they're made of titanium in small numbers and ridiculously expensive.
J
JradM
Alberta
There we go - now featuring a deep carry Benchmade 535 Bugout pocket clip (not the real thing, since that would cost twice as much as the screwdriver, but a $2 aliexpress clone).
Pocket shot.
moab11
Thunder Bay, Ontario
I'm a big picquic fan and have never heard of this!
Strange that they don't list it on their site, but readily available at Canadian Tire, definitely on my list for my next visit.
