Wilton 350SJ vise
pandapike
illinois
So I got this for a steal and I am aware of how rare this model is but what a basket case.
It’s completely seized when it came in still can’t get the jaws apart appears to have a small crack in the body from where the pin was under the swivel jaw also the rear pins holding the female appears to have sheared off.
Rhunes29
Congrats on the find!
Just last week I had one in my watchlist on the auction site that ended up going over $1500.
Try not to destroy the pin in the swivel jaw. I wish I hadn’t because they’re impossible to find.
I ended up using an arbor press and a baby sledge to remove it, but not until after I had cut it flush above & below the jaw.
This model is pretty rare, but still a lot of good info and reference pics on this site.
Best of luck to you & congrats again.
Roberts210
Missouri
You will have to break the rust bond that has stuck the cylindrical portion of the dynamic jaw to the static jaw. Luckily it appears the vise is open a little bit. Pull the handle/screw and then using force push the jaws together and break that rust bond. Once that's done it will be much easier to open the jaws.
P
pandapike
illinois
The pin is going to have to be drilled out. I have done 100’s of vises so no novice but after it’s had heat, Kroil, pb blaster, acid(clr), electrolysis, 1 ton press, 5 ton press, impact gun, mallets, air tools etc. it’s not coming out sadly
