Sealing trailer deck boards
Welderman85
Whats the preferred way to seal deck boards on my car hauler. I can't decide between Thomson water sealer or a mixture of diesel and used oil.
JeepYJ
It depends if you want to use your trailer like the tool that it is, if so then used oil is hard to beat. If you treat it like fine heirloom antique furniture then get something fancy.
But yes there was a recent thread here that covered all the different opinions.
Old Man Roger
Palm Coast Florida
Coincidentally, just yesterday I saw a guy getting used oil from the local auto parts store. Said he was going to make a 50-50 diesel/oil mix for fence posts.
It was the first time I’d heard of it, now here’s a thread on it.
Youngandfree
VA
Very common
Youngandfree
VA
I recently replaced most of the boards on my trailer deck after almost 20 years & now considering a product I had seen in Home Depot once that has a very thick coating when done. I don't recall the name but after looking online I see there are several brands now. This is what looks closest to what I saw....
That stuff seals so well it seals in the rot. I wouldn't use it. I've got stair stringers that or rotting away with that garbage on them. Poked a screwdriver into a bubble in the paint and the wood is rotten away under it. Paint still intact.
APEowner
Sunny, New Mexico
Used motor oil is carcinogenic. Using it as a treatment on a trailer deck is a bad idea. Using it to treat fence posts is even worse and is likely illegal in some places.
I tried a variety of treatments for the deck on my car trailer and eventually decided that steel tread-plate was the best solution for me. You do loose the ability to screw cribbing directly to the deck but in every other way is was superior to wood for me.
u2slow
BC
I dont seal or paint wooden decking. A peeling and flaking finish looks worse than bare wood. Oil or wood preservative for me.
drmarkr
Tucson
Carcinogenic? He's going to walk on it with footwear....not lick, **** or roll on it naked. It's amazing how theoretical risks become blown out of proportion in this society. Particularly in certain states.
JeepYJ
I would think that commercially available stains and finishes are also carcinogenic, oil based stains are made with….oil. I know, used motor oil contains combustion byproducts.
Firebrick43
West central Indiana
Maybe some kids are hungry and they chew on the fencepost and deckboards, you know, like paint chips. ;)
Although I would imagine if a place has fence post the kid probably is well fed.
Ilikeike
Northern Ca.
There are three of my buddy's and I with car haulers, mine has a diamond plate deck.
Theirs are wood, even after treatment, they don't look very good after a couple of summers in sun/weather.
I would treat it with whatever you choose, and then cover with some diamond plate.
I did the diamond plate deck in 2017, painted it with an oil base paint,and bed liner where the car tires run, still looks great.
just an option to think about..
ToddG
I'm in the used motor oil group. I thought I'd try it because I've tried a lot of different stuff and it only lasts a few months in the Phoenix sun. Surprisingly, the oil soaks into the wood quickly and dries. I can touch it within a day and it won't leave any stains. I would not transport a new mattress on it but wouldn't do that on raw wood either.
APEowner
Sunny, New Mexico
Personally, I lay on my trailer when I strap cars down and I prefer to not do that on a known carcinogen, particularly when there are other options
LopezBart
Lopez Island, WA
With traditional wooden working boats, boiled linseed oil + turps + pine tar + japan drier is a popular preservative. It's a bit expensive these days for a car trailer, but works well if refreshed when it starts looking ragged. It penetrates the wood, and the linseed oil polymerizes (sped up by the japan drier). The pine tar darkens the wood, and I imagine helps block the sun. As always, rags, etc. used with this mixture are subject to spontaneous combustion, so toss 'em in a metal can outside. The proportions don't matter much, but 50/50 oil + turps plus some pine tar and a splash of drier works. Takes a day or two to set; can be applied w/ a garden sprayer and mopped in. Somewhat susceptible to blackening. Smells great!
Renegade1LI
long island ny
I just bought a new flat trailer, came with pt 2 x 6s. I thought about sealing it, but if it lasts 10 plus years with out sealing I'll just redeck it.
Hank11
Tennessee
Yes, pressure treated lumber will last a long time with no finish. I am just now thinking about replacing mine that is over 20 years old.
Used motor oil is just a bad idea, but you do you.
Snapped-off
Indiana
What thickness did you go with?
TitusLloydPullo
I'm old enough to see how well linseed oil protected parts of my moms house for over 40 years. I use it on everything wood outside.
I actually sprayed a log cabin with it until there was smoke. I literally watched a trash can of linseed oil soaked rags spontaneously combust once. Be aware.
Burl
Where Mountaineers are free
The guys who put motor oil on their boards are the ones who at 70 MPH on an interstate highway in a nice rainstorm are also coating anyone who is behind them with an oil/water mist. Great for seeing out the windscreen.
JeepYJ
The oil soaks into the wood and evaporates until it’s dry just like an oil based wood stain would. There isn’t an oily mist coming off the decking in the rain.
