Recommendations for Tire Inflator/Gage Assembly?
Beemer
Northeast
Looking for recommendations for tire inflator/analog gage/whip/chuck assemblies.
I don't mean the portable compressor units but rather the add-on end control trigger with analog gage assembly.
I caught a glimpse of my tire dealer's tool and it had a very large (nice) gage but I didn't catch the name.
I've seen listings for Jaco, Topring, Milton and a few apparent copies of Jaco type design.
Use will be home hobby, not commercial.
Dig Doug
I have quite a few
snap on is the best one I have blue inflator W/ gauge
power tank has sone nice ones
Beemer
Northeast
I have quite a few
Thanks.
Snap On anything is to extravagant for my DIY interests...... Home hobby maintenance.
I took a look at a PowerTank, I like the lower pressure range gage but am not loving the gradualtion presentation between numbers.
Dig Doug
You can get a different gauge for the inflator. I use mine for off road stuff - max pressure for my use is more like 35 psi.
Call them They are good people!
or just buy a liquid filled gauge and swap it out….
1/4 standard thread nothing special
I have that exact gauge on my set up and it takes a little bit to get used to reading it
if you want say 17 psi it’s the 1st dark line after 15. I would fill it to the start of the 2nd white line. Seems kinda off, why not just have a hash mark
I don’t sell them or have anything to do w/ power tank - They do try to up their game and have really good quality products…
Beemer
Northeast
How does that Hippo2 chuck of theirs release?
They show a video of it just snapping on but not how to remove it.
Is it really secure when snapped on the valve stem?
AJHD
vavet
Ashland, VA
I see a few on the tirerack website from dill and intercomp.
id be inclined to compare those with some of the other suggestions you have here.
I went around the garage Yesterday with my cordless inflator and set pressure on 3 bikes, one wheelbarrow, a lawn spreader, and the utility trailer (2 tires + spare).
lardy1
I have the Milton mentioned above. It's a bit hard to read for my old eyes but I really have no complaints. I always think I'm going to put a locking end on it but I never have.
Beemer
Northeast
If you want analog, keep it simple.
These are the two I've used and recommend. I've used the Milton working in automotive shops, and I used the Merlin when I worked at Caterpillar.
Milton (USA);
Merlin (Taiwan);
Thanks,
After seeing a dial version at the tire shop that's a preference this time around so the Miltons linked aren't what I want.
I actually have one of those but want to move up.
Vision isn't what it once was so the little displays on those are not useful.
I know that they have a dial version though.
Grandpa made his life working at CAT in Decatur.
Beemer
Northeast
Astro Pneumatic has some nice digital readout options. I have the 3018 and love it. The 3081 looks to be similar but analog.
Thanks.
I want analog because I am bad at ignoring batteries left in things and finding a corrosive mess.
I think less range than the 3081 has would be better for my needs.
Beemer
Northeast
Thanks.
I'll take a look.
I have the compressed air piped in the garage and attached workshop so I don't need a cordless inflator. I have used a portable for the truck when going on the beach and I tended to get impatient waiting around so I prefer the AC compressor at home or an air tank if I'm out of range.
Beemer
Northeast
Exactly, me too. It's gotten the job done but a big dial is actually the objective.
Beemer
Northeast
Do you know where Power Tank are made?
jonesg
northern Maine/
I got this one, it has all the features I prefer,
locks on to tire stem. trigger control and analog meter.
shibertus
Milton (USA);
https://www.amazon.com/dp/B0002SRL20/?tag=atomicindus08-20
Only the hose on these is US made. The body of my unit was poorly machined and the sharp edges cut the rubber hose where it passes through. The gauge was inaccurate, so I had to use a separate gauge to set the pressure. When the hose started leaking at one of the crimps I just tossed it. Unfortunately it seems the quality is not what it used to be.
AJHD
Only the hose on these is made in the US. The body of my unit was poorly machined and the sharp edges cut the rubber hose where it passes through. The gauge was so inaccurate I had to use a separate pressure gauge. When the hose started leaking at one of the crimps I just tossed it. Unfortunately it seems the quality is not what it used to be.
On the Milton? It's been several years since I had mine. So I can't comment on anything current production. But if all that is indeed true, it ***** but also not surprising. Quality overall seems to be going downhill on many tools from many brands over the past few years.
Anyway, I cheaped out and went with the HF Taiwan copy. But the Merlin served me well during my time at CAT. It was used almost daily, mostly on water trucks. Didn't have any issues with fit, finish, function or construction. The hose and crimp held up just fine. Honestly for the price, it's a good tool. Especially if you can get it on sale.
I did however pay full price for the Milton 556 as my large bore inflator. I wasn't going to mess around with something cheap or improvised. At CAT the larger equipment uses large bore valve stems. I was satisfied with that model. I did not experience or observe any fit, finish, function or construction issues. Good extended reach hose, good crimps, great locking quick connect and no sharp or rough edges. Maybe this model is being built differently. I don't know.
Beemer
Northeast
Thanks for all the ideas guys.
I'll update when I make a decision.
Atleast I have refined the requirements: analog, good sized dial, no need for high pressure range so lower top pressure would make the dial less busy.
Wishlist would add rebuildable with removable parts, alternate chuck availability and built in North America. I know that the last one is a stretch but I always atleast try to support our labor force, but not at the expense of quality or required features.
shibertus
Yes, this was the Milton S-506. I thought I was buying a reputable product from a trusted brand, but at least in my experience they are no longer what they used to be.
Azzkker
decatur IL
I've bought 4 of these Milton s-506 in the last year and each one of the Milton are 5 psi or more out of calibration. None of my employees like using them because of this. Sadly they lack the quality they once had.
I bought the blue point unit with round dial gauge and it is much better. Plus it has a lifetime replacement warranty through snap on.
Dig Doug
Pull back on the collar
IMG_9051.jpeg`
Dig Doug
My gauge is older I’ve had it for over 10 -12 years & still works great
I have the European style ( at least that’s what they called It back then )
Dig Doug
You can buy rebuild kits for the inflator and different gauges, They have a digital set up if your into that…
Beemer
Northeast
Communicated with the company and apparently the release is by pulling back the red collar.
scooby074
Nova Scotia
I have one of the old school Milton S506 and an ANI 25 Flex. The 506 is a tank, but its not lock on and it doesnt have a pressure release if you overfill, plus the hose is too short (n)
Ive been using the ANI for several years now, and its plenty accurate to keep TPM's happy and since Ive added the LocknFlate chuck, its just about perfect. Hose is long enough that I can stand up, and off to the side while inflating, which is nice. And it has an air release too.
If I didnt have the ANI, Id probably get the Astro or the OEM Michelin made in France gauge.
Beemer
Northeast
Thanks Dig Doug.
Your name takes me back to the beginnings of video games.
Do you have to have to tighten your various chucks with a wrench or is hand tight enough for quick switches?
I am guessing that you chucks are generic.
I see that PowerTank has quick disconnects that appear less bulky than the Miltons or generics but they are very expensive.
Beemer
Northeast
Thanks Dig Doug.
Are those
They are not very good at email communication; No replies to date.
Beemer
Northeast
This is an excellent, easy to read analog gauge inflator . . .
I saw that product line information. Do you have that particular one? The gage appears to be bigger than most.
Something noted in the specs is that they say it does not hold air as follows:
"Holds Pressure:No"
I prefer to take it off and the reading remain until bled if that is what the specs are referring to.
Also, it does not appear to have a locking chuck that would be a good feature to have.
M6erfan
'Merica!
Something noted in the specs is that they say it does not hold air.
"Holds Pressure:No"
I don't, a friend of mine back in TX does and it is huge and very easy to read. I don't remember if it holds reading until released. My regular (non inflating) Linacre gauges do hold the reading until the bleed valve is pushed. :dunno:
kbeefy
Harington, Eastern Washington
I had the astro 3018 and really liked it, until I lost it.
Replaced it with an AstroAI and it seems fine, but not as nice as the Astro.
I also have several powertank items, they usually have nice stuff.
pelletman
Worcester, People's Republic of Massachusetts
I have a couple digital, probably an old Milton and this one linked below, no way me or my dad paid that much, it probably came from a yard sale cheap. It is almost always the one I go for, it works really well
Beemer
Northeast
Thanks but I avoid that dealer. I'll skip the details.
66HertzClone
Long Valley, NJ
My dad had problems adjusting the pressure of the tires on his lawn tractor. I bought him a dial type and painted a thin red line on the lens for the gauge at the pressure these tires needed. It made it very quick and easy for him to check them.
