Grounding 3-Wire 220 v in a metal junction box?
DanOtn
I'm moving a clothes dryer about 7 feet. The existing Cable is 8-3 (red, black & white) with no ground wire.
I wanted to use a metal junction box but I need to ground it.
The dryer is grounded by using a jumper wire from the chassis to the neutral.
Any reason I can't use that same method to ground the metal junction box?
Thanks
Norcal
That method is now only allowed for existing installations, if you wish to move it you will have to run a 3-wire w/ ground NM cable from the panel to the new location, & use a 4-wire receptacle, as it will have to be brought up to current code.
magic_garage
HAWAII
not permissible to extend 3-wire dryer and stove circuits anymore. run a new circuit which will be safer than the bonded neutral
If you could get a ground wire from the panel to the new location, can you extend those 3-wires to the new location as well and use the old spot a junction-box/splice-point?
Thanks!
Zeke
Thanks!
All wires need to be in the same conduit or in the same cable. So a sister ground wire is not allowed. The OP said he had cable, not conduit so he's better off not touching it as he concluded.
