I have everything loaded up, might grab a couple more lifting chains, but I think I am ready to roll. The mast has two caps the hold it to pins that are welded to the forklift frame, so it should be as simple as put a strain on the mast with Perk, unbolt the caps, lift off the pins. We only have a couple issues, I have no idea of how much the mast weighs and the hydraulic lines could be a PITA. I have estimated the mast framework at about 2000 pounds and the ram at another 1000 pounds, the fork carriage is about another 500 pounds plus whatever miscellaneous stuff is welded to it. I can lift 4400 pounds with the winch and the boom will be good to that weight at a radius of about 22'. I still plan on removing the forks, it will help with loading, plus they weigh another 500 pounds that I wasn't accounting for. The steel was fairly easy to calculate, but the ram is an entirely different story so I guessed based on length and diameter of the rod. Fingers crossed that I am somewhat close, I can also look at possibly laying the mast down until I am under height, but I suspect that will be a nightmare without some sort of cradle to hold it from bouncing around. We will see what happens when it happens, that is about the best I can do at this point.
