I'm planning an addition to my single story house that will add a basement level 2 car garage with living space above (approx. 600 sq ft). THe existing basement is walk out on the side of house where I plan to add, so excavation will be at a minimum. It's really the only logical place to put an addition but, as luck would have it, the set back on that side of the property is 50 feet and the addition would put one corner at 41 feet. A minor variance.... he he. I got my survey and applied for the variance. The zoning board recommends you get letters from abutting property neighbors saying the have no objection to the variance. Of the 3 neighbor, 2 have signed my (ghost written) letter stating such. The 3rd neighbor has 'concerns' which appear to center on the damage the concrete truck and material delivery truck will cause to the private shared driveway. The mostly level driveway dates to 1956, is not in great shape and gets very little maintenance. It is some sort of macadam surface and not especially flat. There are no bridges or soft ground and in fact, there is a lot of ledge rock in the area (southwest, Ct), so chances are, the ground is quite solid under it. This neighbor contends that the heavy construction vehicles will accelerate the damage to the driveway and so is against the variance (the addition wouldn't even be visible from his house).
I have a very hard time believing that a trip up and down the driveway by a concrete truck is going to measurably accelerate the deterioration of the surface. It's isn't like the heavy trucks will be driving back and forth, day after day.... I'm not building a McMansion... Maybe this is a ploy to try and pin the cost of re-doing the driveway on me, alone? I also question if this objection would even be considered by the board since it is, in essence, a private road and has nothing to do with the variance requested (IMHO). I have discussed it with them and explained that no matter what size addtion I put on the house, a concrete truck and heavy equipment will be involved. I am also of the opinion that if I can't do a full, 2 car garage add on, it probably isn't worth doing at all and I do have the option of simply selling the house and then they will have to hope the new neighbor will be content with a small, 2 br house (1350 sq ft). This is an area where it's not unheard of for small older houses to be knocked down and replaced with much bigger ones (mostly 1 -2 acre lots).
Any thoughts? My meeting with zoning board is a week out. I don't know if they actually reached out to talk to the neighbors. Is are a few passes by heavy vehicles going to destroy the road?
