Hohn
A friend has a 2018 Buick Enclave his wife drives. She hit a curb at a dark intersection and bent the LCA to where the vehicle couldn't be driven. Along with another friend from church, we decided to tackle the replacement in the parking lot where the disabled vehicle was.
Well, 90 minutes later, the arm is replaced and bob is officially the uncle.
This was the first time I've used my new extra-long wrenches (Capri zero offset DBEs) and the Tekton ratcheting extra long flex (the previous model 6pt variant). Here are the random learnings from this experience:
- I can't see how a long ratcheting wrench WITHOUT the flex end would be useful in an automotive setting. It's exceedingly unlikely you'll be able to even get the wrench on the fastener without a flex end, never mind be able to advance the ratcheting mechanism.
- The Capris are a heck of a bargain relative to their quality. Perfect for breaking loose the LCA mount bolts. Long wrenches for more leverage are much nicer on older hands and shoulders.
- WrightGrip 2.0s are the best money I've ever spent in tools. The ball joint required an 18mm open end on the nut (thanks GM for having no clearance for even a thin box end). The confidence of knowing that my open end 18mm won't slip is hard to describe. I have busted many a knuckle on open ends and the Wrights basically eliminate the concern entirely. I had to buy the 16mm and 18mm Wrights separately as the standard set skips these, (Yes, American tool company skips ANSI-standard metric hex sizes. SMH).
- Always bring the other pry bars
- and the universal and extensions, too.
- Cordless impacts are a game changer for field work-- where they fit. For this job, mine didn't offer much utility once the wheel was off.
