Toolfreaky
- Joined
- Jul 21, 2022
- Messages
- 51
Building a 1 row firewood rack. The base is 16" wide and 8ft long. It will have a small roof over it. Front post will be 6ft high and the rear will be lower to slant the roof (how much shorter?)
I've been looking at designs, definitely overthinking it but also want it to look good because it will be visible from the road. Otherwise I'd already have it slapped together.
For the 4 posts, should I do 4x4s or a two 2x4s creating a right angle at the corner? Which would be stronger? I feel like the 2x4 corner would give it more rigidity? I think I will be doing the roof like the 4x4 post style; more over hang. Might make it a saltbox roof actually.
If I do thr 4x4, I was thinking the posts would be mounted on the front and back and not on the end, so the stance is wider.
This will be above ground
I will be using pressure treated lumber
this is the two 2x4 right angle style
This is 4x4 post style
