Air_N_Water2000
- Joined
- Nov 18, 2023
- Messages
- 2
I need to modify an existing shop garage door from a 12' x 12' door to a 12'-6" H x 12' door. I've found the required door, but need to modify the header to accommodate the larger opening. Currently, the header is a 3 1/2" x 15" beam, with another 3 1/2 x 2 1/2 beam on top of that then the double top plate. The 2 beams are not glued, just toe nailed to each other. I'm considering removing the top (small) beam, cutting the 15" beam down to 11 1/2" and adding a 2" angle iron along the bottom to increase its load capacity. Would this be strong enough of a header? My other thought was to build a plywood box beam 5 1/2" x 11 1/2". Which is the better option?
For a little more info, this is located in the Pacific Northwest with no snow load required. The roof is a hip roof made from engineered trusses. The opening is in the hip end and the main garage roof trusses run parallel to the wall.
Your thoughts/comments are appreciated.
