Flex head ratchets - Why?
Chrome Vanadium Cody
Why?
Buy one, try one... even the $15 roto from Harbor Freight or something else.
See which you grab first in 6 months.
I agree with this philosophy but just want to say the HF Pittsburgh roto is quick release which I find really irritating. Can’t remove a socket when it’s in the “screwdriver” position. I know it doesn’t really matter and just adds an extra second but still feel like I need to warn about it. Pittsburgh regular flex I’d totally recommend though!
vwpieces
Hills, PA
Takes me more than a second to change the Backward direction dial and make it go the way I want. But for 1/4dr it is my first ratchet I grab. Only 1/4dr flex head I own though.
That makes the release issue nothing. Still worth the $10 I paid for it.
AEAdam
SE PA
Before we leave this discussion, I just wanted to add:
I use my long flex heads for removals. It’s the first ratchet I grab. For these ratchets specifically, I want a flex head that moves the way I want it to, i.e. no looseness or floppiness. I prefer the friction style, bit maybe because I’m comparing my Snap On models to older Craftsman detent styles.
Then I want high strength and a comfy grip. Fine toothed heads are prefered for clearance. Fine teeth are particularly helpful on long handles ratchets. Not that important for shorter handled ratchets.
Low back drag is a plus, but not a top priority. Low back drag extends the usefulness of long ratchets, crack it free and run it all the way out.
My advice, this is the wrong tool to skimp on. You will push this tool’s capability more than any other. These are the first ratchets I use, and the first I would buy.
For standard length ratchets, I look for low back drag, selector levers that are easy to operate. Light weight is a plus because they are faster to swing. These are good tools to try something new. I actually don’t love std length ratchets. If I could have only one ratchet, it would be a long flex. Second, would be a stubby flex, just because they are faster and flex because it conforms to your hand.
Short ratchets don’t need to be particularly strong, fine toothed heads aren’t necessary for swing room. Their chief attribute is low back drag (which MAY require fine toothed heads), then comfort, and a good selector.
Retired dozer fixer
Leesburg Indiana
My first flexible head ratchet was a Craftsman 3/8” long handle. Still have it. Bought new in the 70’s. Back then choices were slim. Still handy. Kind of wish somebody would have made a flex-head ratchet in 3/4” drive when I was working yet. Could have been handy in places. Excavator hydraulic work comes to mind.
Mgdoug3
KY
VolvoRyan
Kentuckiana, USA
It's surprising how "complex" a flex handle ratchet really is. The Youube folks test back drag (on un-broken-in tools), breaking strength (silliest thing ever), and perhaps some (usually flawed) proxy for how "tight" the ratchet seems to be.... but there's so much more to these tools. It all matters.
-Ryan
308guru
Update:
I picked up the Carlyle to give that one a shot. I quickly found out that the reversing lever was very low profile and required a lot of force to use. It was pretty hard to switch. Back to the store it went as I knew I would be forever frustrated with that.
Next I picked up the Icon standard length flex head. This thing is fantastic and quick gained use for many jobs. The high(er) tooth count is great, the reversing lever is easy to switch, and the flex friction was just right out of the box. I liked it so much I added its brother, the long flex head, during the recent HF coupon since I had a need for a long 3/8" ratchet anyway.
These will never replace my 3870, but they will all suit up and likely get equal playing time. Thanks for all of the comments/suggestions.
Banjorear
Essex Co., NJ
It's like a lot of things, you may not need it every day, but when you do, thank goodness you've got one or a few. I'm fortunate to have a few different Snap On flex head ratchets.
The one I reach for a lot is the FHNF100. Really useful ratchet in many situations.
