I'm sure there are a couple ways of doing this, but wanted to get some thoughts on it if possible.
I've got an N3R main panel on the outside of my house (no main breaker which pisses me off, but here we are), and I'd like to install a 240V 14-50 receptacle on the other side of that wall which is inside the garage. This would be mainly for running a welder/shop tools and occasional visitor to plug in an EV. Two options I've been thinking about are:
I appreciate the help!
- Try to run 6awg UF or SER cable from a new 50A breaker in the main panel through the existing hole which runs into the wall cavity, and then right into an old work box for the receptacle in the garage. This seems the most straight forward and best looking option, but I'm not sure if I could fit another cable through that hole in the panel or if that hole even opens up as soon as it gets in the wall cavity. Does it have an elbow that runs those cables vertically into the attic or is it open right after it gets in the wall? What is typical here?
- Drop a short piece of pvc conduit from a bottom knockout in my main panel, into an SLB, and then core a new hole in the brick wall for a short piece of conduit to enter the wall cavity. I think code allows for SER cable in this case as long as the conduit just enters the wall and doesn't go all the way to another box?
