Where to get decent bathroom fixtures?
evintho
Santa Rosa, CA.
I'm doing a little upgrade on a small bathroom. I need to replace the 30 year old faucet and drain in the sink along with a new toilet and I'd like to have some decent pieces. I've read that manufacturers make lower quality toilets, faucets, etc for places like Home Depot and Lowes. Is it better to go to a plumbing supply store? I'd especially like a toilet that flushes strong. I tend to fill up the bowl....haha! Also, funds are limited. Not looking to break the bank but would like toilet/faucet of decent quality. Thanks in advance!
Buckaroo5
Central Ohio
I am old school and buy Kohler or American Standard and usually go through the plumbing supply house. I like the ones that are brass rather than plastic but you do pay for it. If you want to price compare, you can many times find the same fixture on-line at Home Depot as a special order or at build.com. The last three toilets I have installed had the American Standard Champion4 valve - advertised to be able to flush 18 golf balls! I also like the taller toilets vs standard.
Toomanytools?
Washington
Who poops golf balls?
jshillin
PA
Ha, I put 3 of them in my house as well. All 3 comfort height, 2 elongated.
LS6 Tommy
Northern NJ
Kholer or American Standard….Delta
X2. Not in any particular order, but I've been happy with Delta fixtures for a long time. No Grohe or especially Moen for me. Can't count the times I've had to cut out an entire Moen bath valve because a 1 year old cartridge was hopelessly seized into the valve body...
Tommy
geneg
Midwest
Pretty well go with Kohler for everything. I've yet to find that parts were unavailable. Comfort height & enlongated bowls for toilets. Also like 1 piece tolilets (one less spot for potential leaks). I've had good luck with Ferguson & local plumbing suppliers. You can go thru the box stores, but know the"good" model numbers first instead of shopping via their displays.
E
evintho
Santa Rosa, CA.
Any model # for that ASC 4 valve? That's exactly what I'm looking for! Like I said.....I tend to fill up the bowl!
LS6 Tommy
Northern NJ
We have two in the house, one elongated and one round for the smaller bathroom. There's a couple different model numbers, depending on if you want skirted or not, and two or three different flush volumes.
Here's the American Standard page I bookmarked when we were getting ready to redo the main bathroom:
housewolf
East Texas
Build.com. I believe this is the same as Ferguson. I like Moen.
They are and I think their list price is less than full retail. I’m a plumber and have bought from build.com when I wanted something relatively small shipped to my house (80 miles from Ferguson). I usually put it in my cart & my Ferguson salesman prices it for me. I believe if a consumer has a sizable order, they might could call it in to build and get better pricing. Maybe not for a single faucet & drain though but it’s worth a try. They might have something equivalent on sale too.
IME; I like Kohler, Moen, & Delta. Pretty much in that order
johnre
Portland, OR
You didn't mention getting new vs. used, so I'd suggest looking at Habitat for Humanity or similar building reclaim stores. This can get you a heavier casting, better quality porcelain, and full flush volume, all at a low price. And don't worry about the inner plumbing apparatus in the reservoir; it won't matter much as you're just going to replace what's there.
backupbeeper
Not had any more clogged toilets at my house after I instituted a new policy for flushing .
Turd and Third
Flush the turd , then another flush for every third time you drop some TP in the bowl .
My teenagers used to clog the toilet all the time until I came down hard with this requirement .
“I don’t care how much water you use , flush it a dozen times, just stop clogging the damn thing up .”
M.Wong
Seattle, WA
Turd and Third
For the courtesy flush, the flush button in the middle on top of the tank was problematic. Age+back+hip issues = that was just a little more twisting than my body could handle! I am a one-piece Kohler fan, the Gabrielle, Santa Rosa, San Souci...
We recently got a Toto Nexus and found one downside - there is a large hole under the seat mounting area so you can run the power/water lines for a Toto "Washlet" bidet seat. A generic seat doesn't work well, and you are limited to one Toto plastic seat option (with a large base that covers the hole). I prefer an inexpensive soft close wood seat over the plastic ones as they creak less, but couldn't get one for the Nexus.
You can kinda see here what I mean:
nadogail
Coronado, CA
I just had a Gerber installed in a rental. My Plumber selected and supplied it, all i had to do was write a check.
backupbeeper
Yep
I was actually helping someone purchase and install a toilet last week , went to a big box store and they were wanting the one with the button in the middle of the tank and I said no , since you can’t reach it to flush while you’re sitting on it .
“Why would you do that ?”
They apparently never in their life had flushed while still seated .
I’ve gotten a stomach flu a few times and flushed a Dozen times in the same sitting .
GirchyGirchy
Central Indiana
We redid one of our bathrooms in 2016. +1 on American Standard toilets...but check CL or FB Marketplace first, I **** you not (hee hee). Picked up our AS Cadet 3 on there dirt cheap ($60), I think the guy would buy returns or closeouts and sell them. It's been a great toilet.
The bath faucet was in a box of returns I got from a liquidation place, a nice Kohler that still works well. Delta for the shower, still happy with it as well.
gleman
Michigan And Florida too!
:oops:
Oh my... I can't imagine!!!
When we moved into this house, this was the first thing to get replaced!
That's a no go with me!
Years ago a friend bought an old house with an original Crapper with a high cistern. The "detonator" button was on the camode right in back of the seat. I always thought that was the best placement.
mike93lx
Richmond, VA
I'll agree on a real plumbing showroom like Ferguson.
Regarding toilets, anyone with kids should think about a Penguin crapper. They have an overflow built in.... No more turds floating in the floor and ruining ceilings. I put two in after my daughter flooded the first floor half bath
rlitman
Long Island
...Regarding toilets, anyone with kids should think about a pelican crapper. They have an overflow built in.... No more turds floating in the floor and ruining ceilings. I put two in after my daughter flooded the first floor half bath
Never heard of this, so I had to look it up. Penguin toilets have an overflow path that drains separately from the trap. Assuming your clog is in the trap (it usually is) and not the lead bend, that's pretty foolproof.
My last bathroom project included a floor drain for similar reasons. And the floor drain trap intentionally enters the main drain downstream of the tub and toilet (it joins with the sink drain and vent).
It also features a wall hung Toto toilet. My wife complained that the push plate flush on the wall behind you is hard to reach, so I pointed out that if you just lean back on the seat cover, it flushes. The Japanese are years ahead of us.
mike93lx
Richmond, VA
Damn, my bad on the name. Should have looked it up to confirm.
rob1200
California
Yep
You really don't want to flush while you're sitting on it, if at all possible...
toilet aerosolization:
ycgoat
S.E. Va
I put in the Champion toilet decades ago and have not had to unclog a toilet since.
PoorUB
Fargo, ND
I have an American Standard Cadet in the main bath that is twenty years old, great toilet, but I can plug it up once in a while. The downstairs bath has a newer Cadet, one with a 3" flush valve. I rarely plug it up, maybe once a year, and I can do some real "damage" to a toilet!
Ricky Joe
Roanoke, Va.
I was going to recommend Ferguson, but can only add to the previous recommendations. Coincidentally, this past weekend, I visited the car museum in Florence, Kentucky, personal collection of the Ferguson owner before he sold. Saw my first Cord in person ( he has three of them). Pretty nice collection, recommend it.
KevinR
We just wrapped up a build and sourced all the faucets etc from Delta Recertified. It can take a bit of waiting to find what you want, but the prices are pretty decent. No issues so far (hasn't been long) but all seemed good out of the box
