dnschmidt
I've been looking for a cordless soldering iron solution and here's what I've come up with. It's sort of high dollar but if you need to solder something remotely this is a really good option.
1) The soldering iron: https://www.amazon.com/dp/B01MDTO6X7/?tag=atomicindus08-20
This thing is amazing. It heats from room temperature to 300C in ten seconds. It comes with an AC power supply but that's not what I'm concerned about. This will run off of a USB C PD port and Milwaukee has a portable solution.
2) https://www.homedepot.com/p/Milwauk...for-M18-Batteries-Tool-Only-2846-20/313297952
I have an unlimited supply of Milwaukee M18 batteries and this fits right on top of any of them and has both a normal plug and a USB C PD port which is what I want for this application as I don't have to drag around the plug in power supply which is sort of bulky although it works great plugged into the Top Off.
3) The USB C cable that comes with the iron is too short (3 ft) so I bought the following from Amazon which is 6ft and plenty long enough.
You've got about $175 stuck in this rig but it does what I wanted it to do. With the 6 ft. cable I can put the battery outside of the car and have plenty of rope to solder under the dash. Also, there is a lot of things you can additionally do with the Top Off besides power this soldering iron. On it's own it's a worthwhile investment.
