8 point sockets
Junkman
Northeastern CT
Not that often, but when working with older items that used carriage bolts, they are what is needed. It is one of those tools that you seldom need, but when you do, they are worth there weight in gold.
kartracer55
Yes. the 3/8 one on small engine drainplugs... Sometimes they are really tight and its easier/safer to use a ratchet than an open wrench. Other than that, I dont think you will find them on modern cars. Nobody at work has them...
MAD
Western MA
I occasionally use 8 point sockets for removing old square head nuts, bolts, and lags when repairing old equipment or more often salvaging useful parts/lumber. I guess I use the 1/2" 8 point socket the most for hanging and removing theatrical spot lights. The standard pipe clamp for stage lighting fixtures still come with square head bolts. Pipe plugs are another place you might encounter square heads. A 12 point socket will often work for square headed fasteners but chances are these old fasteners have already been rounded a little from someone using an adjustable wrench. If a square head is rounded even a little a 12 point socket will slip. The only automotive application I can think of off the top of my head is the rear brake adjustment and oil drain plugs on my Triumph TR-6.
goodfellow
NoVA
Yup -- I have a set, (1950's vintage Williams Tool Co.) and as was said before, I use 'em mostly on square nuts that are found on pre-WWII British cars. In most cases, the were used to hold wood panels and aprons to steel frames. 12 points will do, but if they are rusty, the only proper way is with a square socket.
SuperKid
Indiana
I don't own a set, but I've used them before, and they're on my "gotta' get list." GM uses them for many newer seat brackets. They're also useful for square head bolts such as those used for the adjuster screw on Rockwell ASA's.
MarkH
Kansas
Used to use them alot on old farm machinery when I started farming. Now so little unless we are restoring an antique. We usually have to track down where we put them. Worth having a set for us, but it is not a high use tool anymore. When I got my first Craftsman kit years ago they were just part of it and glad they were. Glad they are not anymore.
G
george4
N California
Found some hinges on an old shed that are held on by square headed bolts, finally a use for the sockets.:beer:
evintho
Santa Rosa, CA.
I work on a lot of turbocharged Ford 2.3 liter 4 cyl motors. The headbolts have 8-point heads. Typical Ford abnormality. So...........my Craftsman 8-point sockets come in handy, especially the 13mm!
ImportTuner
Who sells 8 point sockets these days? Wouldn't you be better off buying something like the S&K spline set? Just curious ... :)
kartracer55
I got USA made blackhawks for like 10$. No longer USA made apparantly, but these were a good deal. Snap On makes them (I have ONE lol) and Armstrong makes them. Ultimatly I bought the blackhawks because they were the cheapest USA made ones I could find... they are used MAYBE once a month.
Jim
Larz
Kentucky
I need a set. My commercial mower uses a 7/16 square pipe plug. I change oil every 50 hours of use its a pain in the **** to use an open ended wrench.
jerryW
Phx AZ
I've even got a couple of old 4 point sockets! They are nice for the square plugs though.
jerry
Elroy
kentucky
Elroy has been know to use some of his smaller 1/4" drive 8 point sockets on taps. They even make 8 point sockets with specfic special openings just for taps.
chevy302dz
NE
I have a set and use them once in a while. Like most things you may not use them often, but at some point you'll need them. The most common uses for me are on antique's (all different types of things) and differential plugs.
bmwpower
Elroy! Where have you been, brother?
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I paid the price for using some a while back. I've had them for years, and other then the occasional antique furniture, one claw foot tube, I had never needed them. Then I picked up some old iron, that had been moved several times, and had a mix of 6 point and 4 point nuts. My back was tweaked for a month, due to the positions and angles I had to get in (even working with wobbles, and extensions), to get the them apart.
I hope to not have to need them again soon.
GDA
Dallas, Texas
I picked up a Mac set in a garage sale for a couple bucks and use them at least once a year when doing maintenance work on all my lawn and small engine equipment (drain plugs).
