craftsman creep
- Joined
- Dec 28, 2022
- Messages
- 300
I'm sorry that you **** at life, bro.I've seen them laying around my entire life, never used or seen anyone use a "flaring tool". Broke down and got a simple flare tool a couple of years ago, ended up working unsuccessfully on a brake system (go figure) leaked. Never even knew there were dies to make different better flare ends.
Anyway, needed to make a short 5/16 flared fuel line for the backhoe, so I thought I'd give this one a try. Both wonderful and terrible reviews (big surprise).
First try didn't at all and I really can't blame the tool. Suppose to work with steel, but would not budge testing some pieces of Poly Armor, just pushed them down. Come to find out those are some composite steel tubing much harder than normal.
Ended up making a length using NiCopp tubing and things worked just fine.
PASS, glad I didn't spend more for the $70 Maddox kit.
Double Tube Flaring Tool Kit
Amazing deals on this Double Tube Flaring Tool Kit at Harbor Freight. Quality tools & low prices.www.harborfreight.com
To be fair, my first post was a bit low-effort."Pass" in this thread is good, as in pass or fail.
I'm certainly no genius, I think 2ndgearrubber mentioned using NiCopp line, was the way to go and it seemed pretty forgiving.I'm sorry that you **** at life, bro.
Just teasing. I have a flare kit and it took me several tries to successfully repair my S10 years ago. I doubt I could make a profit doing it in a shop.
I can't remember what I used but the successful try was definitely an ohhhhh moment.I'm certainly no genius, I think 2ndgearrubber mentioned using NiCopp line, was the way to go and it seemed pretty forgiving.
Hopefully I'll never need it again. lol
They were kind of a fail for me on my old 5-drawer cart because of peeling off, but all I did was stick them back on and they'd stay for another few weeks/months (longer in winter)
These magnet hooks are great. The hook also screws into the magnet so there area probably some uses where you could screw something else the magnets to use them as mounts.
My concern with “cheap” batteries have been the leakage and damage to whatever they’re used in. Several of the free HF LED flashlights came with “cheap” batteries and many of them failed from the leakage and corrosion. I’m sure the better brand batteries can leak too but I think the odds are less.Firstly let me ask. Has anyone ever used HF batteries? I never have 'cause the very few times I've bought cheap batteries that's exactly what I got; cheap batteries. They seem to be a waste of money at worst and at best the total lifespan of a package of batteries per dollar spent more-or-less equals that of "real" batteries, but you have to be changing them out a lot more often.
I personally haven't had any leakage with the cheap batteries, but I'm sure it's more likely to happen with those than the better ones. In general, they're alright for very low drain devices.My concern with “cheap” batteries have been the leakage and damage to whatever they’re used in. Several of the free HF LED flashlights came with “cheap” batteries and many of them failed from the leakage and corrosion. I’m sure the better brand batteries can leak too but I think the odds are less.
Yeah I have to say those Aldi batteries are also really good for the price.HF batteries are decent in terms of cost for the power delivered, but they're not great in amount of power.
Costco/Kirkland scored very well, as did the house-brand from Aldi (of all places). They're very affordable too.
I repurposed those magnets as you suggested. I have a Kubota tractor that sadly is parked outside and I purchased a solar battery charger for it and for my quad which is also outside. I attached those magnets to both of these chargers and they mount to the arm of the front loader and rack on the quad.These magnet hooks are great. The hook also screws into the magnet so there area probably some uses where you could screw something else the magnets to use them as mounts.
Output/durationI don't understand why people are still using disposable AA, AAA, 9V batteries when the rechargeable ones don't leak, and will last for many years. I'm definitely frugal, but this just makes no sense to me- to risk ruining even a $20 device with a leaking battery vs using a AAA rechargeable that costs about $1 and will probably last 10 years.
I generally agree, but in some cases the difference between the nominal voltage of a NiMH battery and an alkaline battery is enough (especially when several batteries are used in series) that some devices will just not function properly, or they will only function for a short time until the voltage drops below some threshold.I don't understand why people are still using disposable AA, AAA, 9V batteries when the rechargeable ones don't leak, and will last for many years. I'm definitely frugal, but this just makes no sense to me- to risk ruining even a $20 device with a leaking battery vs using a AAA rechargeable that costs about $1 and will probably last 10 years.
i get AC Delco at Gabe's. they ok for clocks and TV remotesI know HF has probably changed their batteries but I will never buy them again over all the leakages I had years ago. Even when they were giving them away for free I never accepted the offer. For inexpensive leak-free batteries you can get Exide at Rural King or Rayovac at Menards.
That same dolly is 9.99$ at home depot all the time, just bought a few.These dollies are definitely a pass. Over the years I've accumulated 18 of them and nearly all of them are used to "semi-permanently" store something. i.e., a couple have 4-speed transmissions on them; a couple have totes/boxes of "I'll need this stuff someday" on them; etc., etc. Seems like when I need one (or more) I have to go buy more 'cause they are all in use. I bought four of them a while back to connect with 2x4's to use as a platform to move a Model A body around on but used them for other stuff before I got them put together. Guess I'll have to run to town and get more.
And right now they are on sale.
You can't buy the casters for this price, and then there's the labor and materials to build a dolly if you do buy the castors. I've never put an engine on one, but they claim to be able to hold 1,000 pounds which is more than just about any engine, short of diesels. I'm afraid the footprint isn't big enough to be very stable with an engine on one though.
Don't bother trying the dollies for that kind of load. The long dimension will 'swayback' with time, and then your 'up-to 1,000 lb load' will be dangerous.I've never put an engine on one, but they claim to be able to hold 1,000 pounds which is more than just about any engine
Good job there driftpin. I've made several nearly identical to yours thus never needing to use the HF dolly for an engine. The one mistake I made on one of them is that I didn't have 4 "crazy wheel" casters and that one doesn't turn when I want it to.Don't bother trying the dollies for that kind of load. The long dimension will 'swayback' with time, and then your 'up-to 1,000 lb load' will be dangerous.
Buy the small dolly, remove the wood, and use 2x4 and 2x6" pieces through-bolted to the caster plates. Then you can place a 327 on one (that's what I did, until I sold it).
Something like this, but these are ball-bearing 4" casters, w/brakes. The particle-board platform was on there to provide a larger flat space for something bulky, and will not be staying...
