Soffit downlight recommendations
draker541
Hello.
I'm looking for some down-light LEDs to install in the soffit of my shop. I've tried a few options and have had mixed results. The thin 6" puck lights have too wide of a throw on the light. I also tried some smaller 4" lights, which I've attached a picture of. The lights are really for aesthetics and not really for usable light. I may add a flood light or two later if I need it. I tried some barn light style lights that mount on the wall, I like the look but there isn't a lot of room from the top of the garage door to the soffit.
What have you had success with?
D
draker541
I assume this is around the building, shining/washing mostly on the walls?
Sorry I meant to attach a picture to the first post. But it didn't attach. I've attached it separately in another post.
Basically just two lights over the bay doors. These doors are around 11ft wide, 14ft tall. This is just me surface mounting the light to get a visual.
D
draker541
sparky 1971
Central Iowa
Are they listed for a damp location?
Yes. According to Halo, they are listed for a wet location but I have my doubts about that. I used some in a soffit, but the metal soffit material was a little too thin for the springs to work right. I made some shims out of 1/2" plywood and all is well.
D
draker541
I’m going to pick up two of the 4” gimbal light and give them a go. I think it’ll look similar to the picture I posted above. I’m fine with that.
Buckaroo5
Central Ohio
Installed some of these HALO white color selectables in my kitchen. The 4" gimbal floods and the 4" narrow beam. I also installed some 6" floods. I also have them all set at 3000K right now. Very nice lights and easy to install. FYI, I bought one of my 6" floods from HD and the rest from ElectricBargainStore.com because the were cheaper. Although they had the same model number, the HD one was newer (I think) and was a little different color. I called the HALO folks and they figured out it had a different ART number, so was a different version They sent me another one to match the rest of the lights no questions asked.
