tominboise
- Joined
- Jan 17, 2022
- Messages
- 195
I am working on a project and need to weld this 1/2" plate into the interior of this 3X3X1/4" angle. The angle is 50" long and there will be a plate welded in at each end and one in the middle. I have TIG and stick available and am planning on TIG welding this. I will grind bevels on the 1/2" plate to get good penetration at the root of the joint, and sand all the rust and scale off. How best to weld this out, as I would like the angle to be as square and flat as possible when I am done.
Also, should I preheat this plate and angle prior to welding it out?
