Electric Motor Start Capacitor
D
D45
NW INDIANA
Awesome yes that's the capacitor size
Looks like the cover needs to have top and bottom mounts, not on the sides
D
D45
NW INDIANA
Here's the cover area
RPH
Michigan Thumb
Higher voltage capacitors are physically larger due to the increase in the insulation between the poles. Higher voltage will jump the gap between the plates. Once started it’s usually over microseconds later in a bang. Polarized caps are even more fun with the bang and confetti falling.
exmaxima1
Midwest
I wouldn't bother with fabricating a cover until I tested the motor with the new capacitor. As noted earlier, there might be an issue with the start winding or the centrifugal switch since the original cap and cover are missing.
nadogail
Coronado, CA
AC ( Alternating Current) capacitors are not Polarity Sensitive. Either way you hook it up will be fine.
DC ( Direct Current) Capacitors are often Polarity Sensitive.
The Cobbler
here's what I have
both are just shy of 2" wide ( inside measure) x4 " & 5" .
the mounting tabs are on the sides . both have semi good seals . moving the tabs would be an easy job , but if you were careful you could probably re drill the motor case. cover shipping & 1 is yours . but, not sure about shipping to US from Canada , it's probably at least $25 by Canada Post ,
D
D45
NW INDIANA
Thanks for all that
For now, I am going to try to find a capacitor cover to fit the preexisting holes in the motor case
bronc076
Ozarks
I like the soup can idea above. I had a bunch of vintage steel beer cans I gave to the local barber shop as they use them for decoration. I would have sent you a couple for free just to see the final product!
D
D45
NW INDIANA
I took a capacitor cover off my Craftsman drill press, it was a close fit......but I also can't find the part number for that haha
larry4406
Northern Virginia
How about a short piece of pvc pipe say 2” diameter?
Wafer cap glued on one end, other end push on cap (no glue).
Drill thru sides to align with your motor’s threaded holes. Use different size holes. Hole closest to motor just clears the bolt thread while hole opposite is larger diameter for nut driver/screw driver/hex key to clear. Use washers as standoffs between pvc and motor to provide clearance for hub of push on cap.
D
D45
NW INDIANA
I really want to find a used cover that fits
Has to be many similar motors with very similar specs and mounting hole pattern
Like I said the cover on my craftsman drill press was very close. I could make that work, if I knew the cover part number! Haha
D
D45
NW INDIANA
Does the capacitor just sit inside the cover or should anything be used to help with vibration and insulation
The cover arrived and fit well
I'll get some pics of soon
mike93lx
Richmond, VA
I'd put in a piece of foam if for no better reason than rattles drive me nuts
  • Like
Reactions: D45
larry4406
Northern Virginia
On the Dayton’s I posted pictures of, there was an indent on the side of the cover which created a snap force fit with the capacitor. It holds it snug.
What is odd is that mine have the leads at the bottom so gravity works against it. At some point in time the leads could probably ground out if the capacitor slipped making things unhappy.
D
D45
NW INDIANA
I will pack it with something to prevent movement and vibration and also wrap the capacitor connections with electrical tap
D
D45
NW INDIANA
Does the motor have to be grounded to the lift frame?
Or is running the power cord ground to the motor sufficient?
micromind
Fernley, Nevada, about 30 miles east of Reno.
The motor needs to be grounded at the motor frame no matter what.
If it has a rigid base, the machine can be considered grounded by the mounting bolts. If it has a resilient cradle base, (rubber mounts), you'll need a jumper from the motor frame to the base. The factory has installed these for many years.
  • Like
Reactions: D45
